Old 11-30-2008, 07:45 PM   #1
orangek5
orangek5's Avatar
Lower Radiator Hose?
PO installed a 78 305ci in my 72 c10 and the incorrect radiator. I just so happend to have a radiator out of a 69 blazer R.I.P. but the lower hose the PO installed was a universal flex rubber hose and it is too short. Now my ?. Will 1972 SB chevy truck lower radiator hose fit regaurdless the CI of the engine or do i need to find a longer flex hose?
Thank you for any input.
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 11-30-2008, 08:11 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Lower Radiator Hose?
A small block is a small block when it comes to these things.
If you have a short water pump, buy a hose for a 72 truck.
If you have a long pump, get one for a 75 model truck.
Don't run a flex hose, they strain the radiator bung too much. Get a proper molded hose. They are still readily available.
Old 11-30-2008, 10:54 PM   #3
orangek5
orangek5's Avatar
thanx Tx firefighter thats why I ask the experts!
1970 Jimmy 4x4 IL6
1971 SWB 327ci v8
