Old 11-30-2008, 09:18 PM   #1
leatherhead63
Turbo 350 NP205 Leak
My Turbo 350 trans is loosing fluid and my NP205 is leaking on the
output shaft. No visible leak at the tranny. I have heard that the coupling between the two can be the problem. Is there a path for fluid between the
tranny and the TC
thanks
leatherhead63 is offline   Reply With Quote
Old 11-30-2008, 09:29 PM   #2
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
Re: Turbo 350 NP205 Leak
The seal's in the trans/case adapter are bad and fluid is bypassing them and filling the case.Pull the fill plug in the case and see if the case is overfull with ATF.
1-tonmudder is offline   Reply With Quote
Old 11-30-2008, 09:30 PM   #3
Cyclone
Cyclone's Avatar
There are two seals in the transfercase adapter, one to keep trans fluid from going to the TC, another to keep the TC fluid from the trans. Sounds like you need to drop the transfercase, remove the adapter, replace those two seals, re-install.
Picture see#37
Cyclone is offline   Reply With Quote
Old 11-30-2008, 09:37 PM   #4
leatherhead63
did a search and found the same advice. Thanks.
Old 11-30-2008, 11:17 PM   #5
hdflstf
hdflstf's Avatar
Actually there are 3 seals. Been there done that. There are 2 seals on the outside diameter of the coupler (these are the likely leak path). Pay attention to the direction they are installed since they are backwards from what you would normally see.
Third seal is a thick o-ring on the NP205 input shaft which seals with the inside diameter of the coupler.
hdflstf is offline   Reply With Quote
Old 12-01-2008, 12:49 AM   #6
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Yep thats true. I just did that on my th350 and 205.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 12-01-2008, 01:25 AM   #7
leatherhead63
I see I;m not the first. Thanks for the good info. Just got it back on the road. will most likely wait a week or two before tearing it down. Need to fix or replace a leaky power steering gear box first.
Old 11-02-2009, 02:30 PM   #8
shiner
shiner's Avatar
I've recently got the same problem. Quick question though, today's Monday and I'm planning on going camping/hunting this weekend, about 180miles round trip. What kind of danger am I looking at driving it this way? Its opening weekend by God.
shiner is offline   Reply With Quote
Old 11-02-2009, 07:02 PM   #9
Gene
Gene's Avatar
Ran into the same problem, took my 205 to my transmission guy to check it out and install new seals while he was changing my output shaft to a shorter one on my TH350, and when he pulled the plug there was more AT fluid than gear oil. He assured me that it wouldnt hurt anything and it's pretty common.
Gene is offline   Reply With Quote
Old 11-02-2009, 08:58 PM   #10
Chevy1TonFun
Grease Monkey
You should be fine. I drove my truck for months with ATF leaking into the t case. Its just annoying. Just take some extra AT Fluid with you.
Old 11-02-2009, 10:07 PM   #11
Thealien
Thealien's Avatar
Been doing this for a year. Don't let your transmission get low!
Old 11-03-2009, 11:50 PM   #12
shiner
shiner's Avatar
Good deal, thanks for the quick replies.
I pulled the plug on the tc, but had gear oil run out. I'm going to clean up the bottom and see if the fluid is coming from the tranny.
Old 11-04-2009, 07:13 AM   #13
My`92 K3500 is doing this,but it`s a manual.My NV4500 started whining so I drained the fluid and about a quart came out...no leaks showing anywhere.I left the t-case overall and just filled the transmission back up and all is good until the next time something needs to come out.You can`t hurt the t-case and even if it builds too much pressure it will puke out the vent.I still check levels periodically in case it decides to swap directions.That`s the only thing i`d worry about,is if the gear oil gets into the trans,although the thinned lubricant will leak before the thicker.
Old 07-16-2011, 10:54 AM   #14
fleetmitch
fleetmitch's Avatar
To follow up, can the leakage problem from Turbo 350 to transfer case also cause downshift problems in the tranny? Admittedly, my trans fluid level got low before I found that it was leaking into the transfer case. But now my transmission won't downshift to first gear at a stop sign. Otherwise, it shifts fine - either manually or if when stopped, I move the lever to first and then back to drive prior to pulling away from the stop sign. I pulled the pan and valve body, and found a very small amount of metal dust (we did a rebuild just a year ago) in the pan and everything in the valve body worked OK. We replaced the detent cable, and even tried adjusting it all the way in. Can there be a pressure issue, whereby not enough pressure (due to bad seals) that the tranny won't downshift?
fleetmitch is offline   Reply With Quote
Old 07-19-2011, 01:43 AM   #15
slider
I'm going through this right now, turned out my case was bad, found a k case, taking it to my tranny guy in the morning, just hope its a good one.
slider is offline   Reply With Quote
Old 08-24-2013, 02:15 AM   #16
robs71k5
K5drive
robs71k5's Avatar
I found this I info here and I believe this to be the issue with my truck Question is can these seals be replaced without totally dropping the tcase maybe just sliding it back a couple inches to get clearance for new seal installation and or would it be an expensive gesture to have it done at tranny shop. Thanks
Picture see#37
robs71k5 is offline   Reply With Quote
Old 08-25-2013, 01:17 PM   #17
fleetmitch
fleetmitch's Avatar
The "adapter" is a short shaft - several inches long, as I remember, and thus you will need to disconnect the transfer case to get it out. In my case (no pun intended), I had Transmission Fluid (which is lighter than transfer case oil), running out of the lever selector rod holes - near the top of transfer case !
Old 03-24-2014, 12:31 AM   #18
DSST_construction
Does anyone have pictures or part numbers to order the seals? I need to do this asap
DSST_construction is offline   Reply With Quote
Old 03-27-2014, 07:56 PM   #19
Orange Crate
Orange Crate's Avatar
Here is a post from July last year going over this same issue with answers about the seals.
http://67-72chevytrucks.com/vboard/s...ighlight=NP205
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
