Old 11-30-2008, 11:10 PM   #1
1969 SSR1
Question
I have a new battery and alt but yet my headlights still go dim them regular when i drive it. Its like something is pulling my juice from somewhere.
1969 SSR1 is offline   Reply With Quote
Old 11-30-2008, 11:11 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Question
They look dim all the time or gradually go dim?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-30-2008, 11:25 PM   #3
1969 SSR1
Re: Question
its like they cut out for a second and then normal but its very noticeable. hard to explan.
Old 11-30-2008, 11:29 PM   #4
Sport/Truck
Sierra Grande Club
Re: Question
could be a ground issue or something going wrong with your switch. Make sure your grounds are not rusty at the areas that they connect etc.
I'm not 100% on this but just what I would check. Hopefully someone will chime in and offer some advice.
s/t
Old 11-30-2008, 11:32 PM   #5
1969 SSR1
Re: Question
Thanks. Also remembered that my bright lights dont work anymore. You can really see them go dim when i turn the heat on.
Old 11-30-2008, 11:35 PM   #6
Sport/Truck
Sierra Grande Club
Re: Question
Thats probably your switch. AFA them going dim......well I think that's normal.
You can do the relay mod to fix that problem and they'll end up much brighter.
s/t
Old 11-30-2008, 11:37 PM   #7
1969 SSR1
Re: Question
is that an auto zone buy? Thanks for the info.
Old 11-30-2008, 11:41 PM   #8
Sport/Truck
Sierra Grande Club
Re: Question
The parts are, but you need to go the the truck FAQ page and get all the info.
s/t
Here the link....http://67-72chevytrucks.com/vboard/s...archid=1015655
Old 11-30-2008, 11:43 PM   #9
1969 SSR1
Re: Question
thanks brother
