Old 11-30-2008, 11:12 PM   #1
Ricks1971
Ricks1971's Avatar
4X4 shortbed frame?
I have a bare 4X4 shortbed frame and was told when I got it that it was a 68. But today a guy came by to look at some parts I have for sale and was told it was a 69-70 frame. My question is if there is a difference how can you tell the difference between a 67-68 to a 69-72 frame? Thanks Rick
Ricks1971 is offline   Reply With Quote
Old 11-30-2008, 11:26 PM   #2
Cyclone
Cyclone's Avatar
Re: 4X4 shortbed frame?
saw this in an earlier post re: 67-68 4x4 frames
"everything on 67-68 suspension and steering is different and springs will need to be custom made OR swap all the mounts from a 69-72 which is what i would recommend. the front spring mounts on your 68 are cast and prone to cracking if your truck is going to be wheeled hard. "
Cyclone is offline   Reply With Quote
Old 12-01-2008, 08:14 AM   #3
The spring perches are the difference and are interchangeable.But,what you have is better.If it`s bare I`m not sure how it couldn`t be a 71/72.
Old 12-01-2008, 09:48 AM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
I think you can tell by looking at the area where the steering box mounts but I might be wrong. I think the 69 and up frames were dimpled and most 68's weren't but I think some may have been.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-01-2008, 08:30 PM   #5
msgross
msgross's Avatar
couple of ways, if the frame area behind the steering box is "flat" then its a 67-68 but that's not always 100% true. If it has the raised pads then it more than likely is newer. The emergency brake cable brackets are a little different. And the big sign is the rear springs. They are longer on the 67-68 that's whay they don't sell lift kits for them. Send some pics and we might be able to help. No big issue either way except for the springs.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
