Sierra Grande Club
tricks for getting the front clip on
I'm trying to mount my radiator support and fenders. But my fenders are not lining properly. I'm thinking the new rubber radiator support mounts need to be tightened up to make the reveal correct.
Am I over looking anything? How do I keep the radiator support level - or does it even matter? (As long as the fenders reveal are correct) Do I need to measure or install the hood to make the front clip square somehow? Please share your tricks or other strategies to make this as smooth as possible. s/t ![]() ![]() ![]()
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
"THE GREEN GOBLIN"
Re: tricks for getting the front clip on
Sorry I can't help you but I'd Like to Subscibe if its ok with you I will need this some day I just have to finish up my wireing then Bring the pressure on at the body shop where my doors and fenders have been waiting to get painted since January its going to be a year and they still haven't even seen paint Every time I call they say they haven't done any work to them and they will work on them on the weekend Yup Thats maybe an hour a weekend they are lucky I'm a very patient guy I just don't want to loose my $500 Down But it has given me time to clean up my engine bay..I am for sure going to ask for a Discount
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 12-01-2008 at 08:56 AM. |
Sierra Grande Club
Subscribe away! I thought this would be easy but the more I thought about it the more that could end up wrong!
I’m wondering if I should use a tape measure to square off the fender to the radiator support to make them square, then install the hood to check fitment. We’ll see. Good luck with your project. s/t
"THE GREEN GOBLIN"
That is exactly what I'm afraid of when I get to that point I thought the fenders would be easy What scares me is the doors and scraching the Paint.....Even thought of paying some one to put them on but it feels better to do it myself....
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Square the core support with the cab. The cab is still in the original position, but you pulled core correct? The support holes in frame have an allowance for quite a bit of adjustment. Did the fenders have any shims at the top or lower attach points? To get the top and bottom to sit flush at the door you may have to shim them out- also there are different thicknesses of shims to get the desired effect. I suggest that you put everything together loosely so that you can adjust the squareness of the clip. If you put the hood on you will be able to see if the clip is out of square as well, just don't slam the hood
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#6 | |
Sierra Grande Club
I have all the shims for the fenders in their correct spot. The fenders look great shim wise, It's just too high at the radiator support, causing the gap at the bottom to be too wide. While thinking about this i was concerned about making the front clip square. Anyone have neat tricks for setting this right the first time? s/t
![]() Join Date: Oct 2006
If you changed your core support mounts and not the cab mounts, that would be why it is high. the cab mounts are most likley degraded. If not, and the support is still high after you tighten the core support then you will need to shim up the cab.
#8 | |
Sierra Grande Club
s/t
