![]() Join Date: Oct 2007
dash options
I am planning on putting a Vintage Air type system on my 70swb. The cab is toast however, the dash is good. It had factory air. I have a cab from a 70lwb that I’ll put on the swb frame. It did not have factory air. So should I swap the dash or is there another option to vent the AC? Does someone have a template to cut the vent holes in the non AC dash? I’m not going for a stock restoration. Thanks.
Under Construction
Re: dash options
you can get templates to cut the AC holes from most aftermarket AC companies when you buy a system from them. I am sure a boardmember has the template and would be willing to share.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Next project: 1970 K10
Re: dash options
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Re: dash options
member #16
![]() Join Date: Dec 1999
Re: dash options
Heres the templates. If you P.M. me a postal address I will send them to you, including the center vent. These posted will not be sized right if printed.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
chevy truck fan
Re: dash options
i have a universal vintage air system in my truck & used the directions from the "factory-fit" system that they sell. the directions are on their website & you can print them off which includes the "full scale" sheet needed to tape to the dash & sides for the hole locations... hope this helps & good luck!!
Tot Roddin'
Re: dash options
Sounds like everyone else beat me to the answer... fast work guys!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: dash options
Thanks ya'll. I noticed there are ~45 spot welds on the leading edge of the dash, cutting holes sounds the way to go.
its all about the +6 inches
Re: dash options
if you have an A/C dash there... you can make your own templates pretty fast.
![]() Join Date: Jan 2008
Re: dash options
I made my templates off an air dash.It's a piece of cake,you'll have no problem.I used a jig saw and a die grinder with a carbide burr.Good luck
