12-01-2008, 02:21 PM | #1 |
window hard to roll up
My driver window rolls down just fine but going up is another story. First, the glass starts to pop out and doesn`t stay in the door which I`m guessing is my problem. I have to guide the glass to get the window up. I`m more afraid of my crank breaking off than the glass popping all the way out. How do I fix this and is it a easy (read that as cheap) fix?
Anthony |
12-01-2008, 02:23 PM | #2 |
yeller
Re: window hard to roll up
Check your rear window track/guide. My 77 had the same problem, turns out the weld broke between the track/guide and the mounting tab.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-01-2008, 02:42 PM | #3 |
My passenger side window acts similar, it's easy going down, but almost impossible to go up. It binds up, I worry about breaking the crank or window, and I have to pull up on the window while cranking it. I found out over the weekend that one of the track rollers is broken off.
'71 C25 Camper Special, 402, TH400, Longbed, Power Loc axle, Figuring out the rest of the details.... '10 Dodge Charger SXT - DD '91 Kasel M101A2 3/4 ton trailer (It has Chevy rims!) |
12-03-2008, 01:43 AM | #4 |
Thanks guys. sorry it took so long to reply. I`m in the middle of another repair at the moment. I`ll take a look at the rollers and see if thats the proble. I want to go to power windows eventually.
Anthony |
12-03-2008, 01:48 AM | #5 |
It followed me home?
Can the rollers be replaced? if so has anyone done it, and how hard was it to do?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
12-03-2008, 02:18 AM | #6 |
Yo! I've done full rebuilds in my '68 Mustang, '76 Camaro, and '78 K20 (to name a few!) and all of them have simply involved a wire clip holding the roller onto a shaft. Piece of cake! With the door panel off, you'll be able to assess your particular situation, find the right vendor for the rollers, and see how easy they are to replace. Window position, up, down, or in-between, will put each of them within reach. I use EP grease in each track and on the rollers for smooth, easy function. Don't forget to clean and grease the crank gear!
As mentioned above, my '69 F100 has a track that has a fractured weld and I'll have to figure out a proper fix for that,...probably remove, spot weld, and re-install. When I can get to THAT! Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
12-03-2008, 08:02 PM | #7 | |
(P.S. '73 has little rollers, '76 has bigger rollers, not interchangeable. $13 lesson.)
