Need Picture of Linkage
Does anyone have a picture of the original 2wd 350 turbo column shifter linkage from the trans to the frame? Also, I haven't looked under the truck yet, but is there factory holes for the trans linkage mounting bracket. The reason I ask is that my truck was originally a 3sp manual. Just wondering if all frames have those holes. thanks for any help.....
1997 GMC Sierra Ext 1965 Mustang |
member #16
![]() Join Date: Dec 1999
Re: Need Picture of Linkage
Maybe this will help. Cant answer about if holes are in the
frame. http://67-72chevytrucks.com/vboard/s...d.php?t=316983
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Neighborhood Pickle Slinger
I donīt know what the linkage looks like for a 350 but here is the one I have on my 400.
Hope it helps a little. The notch was cut out to make room for the exhaust.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
Moderator
![]() Join Date: May 2007
I would use Lokar or Kugel Komponents linkage kit. Hassle free, easy to install, and a way better design than factory linkage. There are only 2 pivot points in it, and you will never have sloppy shifts again. Plus, if you have a 700 r4, you can dial it in so your shift indicator lines up perfectly
Thanks for the pics guys. That's exactly what I was looking for. I am using the Lokar linkage kit now & hate it. I've tried adjusting it per instructions & without. It never lines up to the shifter indicator & I get engine vibrations thru the column. Going to try this factory setup & see if it is any better. It worked for the GM Engineers, so we'll see.
Moderator
Maybe Kugel is different then...I thought they were similar. I use Kugel and it took me less than an hour to install/dial it in. If you get the stock linkage to work that is great!
