Old 12-01-2008, 08:11 PM   #1
Blazer Eagle
power doors, what to do with the window?
i need to either roll it down or take it out and i dont know how to do either because its not connected to a truck their on their own
Blazer Eagle is offline   Reply With Quote
Old 12-01-2008, 08:36 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: power doors, what to do with the window?
Not sure exactly what you are trying to do but if you need it move just cut the wires behind the switch and hook it to an 18v battery
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-01-2008, 08:41 PM   #3
Blazer Eagle
im converting it to a blazer door so i cant cut the frame with the window in the up position, is that the easiest way to use a battery, i have all the wires out in the side of the door so i can connect there but i dont know which ones to connect to
Old 12-01-2008, 08:54 PM   #4
cochino12
cochino12's Avatar
just pull the switch out of the panel so you know what color's to use.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-01-2008, 08:57 PM   #5
Blazer Eagle
the motor has a blue and beige wire going to it, the switch has a blue beige and pink wire going to it, and theres also a ground, what do you think would work? also what kind of battery should i use?
Old 12-01-2008, 09:01 PM   #6
cochino12
cochino12's Avatar
sorry I'm dumb, hook it to the wires on the motor not the switch, if it goes the wrong way switch the polarity on the battery. You can use a rechargable battery for a drill or similar
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-01-2008, 09:21 PM   #7
Blazer Eagle
oh thatll work, ill try it when its light tomorrow
