Old 12-01-2008, 10:05 PM   #1
vin63
It's Better With Nitro
vin63's Avatar
Torsion Style Rear Sway Bar
Anybody else run into space limitations on the rear of our trucks and have issues with the traditional rear sway bars (with the links that mount up to the frame and 3-sided bar that mounts to each trailing arm)? I did, so I ended up building a torsion-type rear sway bar assembly. I had a left over 5/8-inch 36-spline sprint car torstion bar, and I used 1-inch tubing for the torsion bar housing, which also solved the problem of the crossmember the previous owner cut out to install a drag race type of fuel cell. Anyway, I had some spare time over the holiday weekend and did some fabricating. Below are a couple of photos of the mock up. Is anyone else running a torsion type rear sway bar?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-01-2008, 10:22 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Torsion Style Rear Sway Bar
Looks good man....you may want to post in the suspension forum.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-02-2008, 02:41 PM   #3
vin63
vin63's Avatar
Thanks! The hardest part was bending those dang torsion arms uniformally. Man, that 6061 T6 aluminum is tougher than most people think.
Old 12-02-2008, 03:00 PM   #4
kizer
Its Deja Vu time again
kizer's Avatar
Sway bar whats that? Well at least my truck doesn't have one and I know the benifits of having one very well.
Reminds me a lot of the AntiRock
http://www.currieenterprises.com/CESTORE/antirock.aspx
Keep in mind it will allow some travel. Not as much, but it will allow travel.
Jeeps will have more body roll than stock. This Sway Bar may be used on the street, however it will not provide the same performance as the stock setup.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 12-02-2008, 03:09 PM   #5
kizer
kizer's Avatar
Heck just looking at that, I wonder if that would be a different idea opposed to a tackbar or a watts link?
Old 12-02-2008, 08:16 PM   #6
vin63
vin63's Avatar
The reason I built a torsion bar style rear sway bar is because I only have a dual control air system (front and back as opposed to a 4-way controlling each air spring). I know it would probably be better to control each rear bag, but that's what I had, and this was cheaper than buying new air solenoids and controller/gauges.
The spherical rod end links provide to much misalignment in a sway bar configuration to properly center the rear end. That's why I'm running a 35-inch J-style track bar from the driver side frame to the rear of the passenger side trailing arm - I was thinking of replacing the urethane-bushed ends with spherical rod ends, but I think it will make the ride harsher.
