Header Havoc
Put a set of longtube Hooker headers on my 69 swb 525/th350 and I can't put my truck in 2nd or 1st gear because my factory linkage hits the header as it rotates down. Anyone have this problem? Can I just cut the u shaped piece till it clears my headers and extend the rod that bolts to the frame under the cab or is there a better option?
Nothing to see here.....
![]() Join Date: Jun 2007
Re: Header Havoc
if I remember right, Hedman headers has a concave section in that location that remedies that issue.
may be time for a torch and a ball peen hammer.....
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 12-01-2008 at 10:21 PM. |
Re: Header Havoc
To fix my issue I would have to completely beat one of my primary tubes shut. Not to mention they were $400.00.
Re: Header Havoc
Both Lokar and B&M have shift linkage/cables to get around this issue.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: Header Havoc
As far as the geometry goes, the u-shaped bar can be any shape as long as the part that engages the shift lever remains in the same place and you don't cause interference anywhere else.
Re: Header Havoc
I switched to a Lokar shift rod for this very reason. My indicator lined up perfectly with it and shifts were much firmer.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
