Old 12-01-2008, 10:23 PM   #1
shrtbx
MSD BOX locations please.
Whats a good spot for an msd box in the engine bay? I usually see them on the firewall but i dont think i have room for it there.
shrtbx is offline   Reply With Quote
Old 12-01-2008, 10:38 PM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: MSD BOX locations please.
I put mine on the fenderwell.. it gets good airflow there. They get HOT!
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 12-01-2008, 10:51 PM   #3
shrtbx
I was thinking along those lines as well. Thanks man
Old 12-02-2008, 01:09 AM   #4
bigblock73
yeller
bigblock73's Avatar
Here is mine
bigblock73 is offline   Reply With Quote
Old 12-02-2008, 08:13 AM   #5
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Dang Jeff!
That's sweet.
BTW, mine is a digital 6 and is bolted to the cardboard insert of the glovebox. The HVC Coil is mounted on the fenderwell near the battery (see below). It's not as clean an install as Jeffs though. The box does stay cool. I've checked several times after having it out running. You know, if it's cool air you want, that's a pretty good location if you have A/C. The A/C duct runs right above the glove box and a strategically placed hole and routing of air will keep it cool even when you have just outside air on it if you think about it.
87Lowrider is offline   Reply With Quote
Old 12-02-2008, 08:28 AM   #6
1985K10
1985K10's Avatar
I have a 6AL mounted to the back of my glovebox in my 70 Chevelle. Only problem is listening to it hummm with the windows up and the radio off...
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 12-02-2008, 09:35 AM   #7
redrat
gearhead
redrat's Avatar
i mounted mine on the fire wall and ran all the wires behind it. every thing else is hiden..
2003 GMC Z71 Daily driver
1982 Chevy 2wd short bed, project,
boxerdra@hotmail.com
redrat is offline   Reply With Quote
Old 12-02-2008, 05:09 PM   #8
Pyrotechnic
Pyrotechnic's Avatar
I'll try to get pictures later, by my 6A is mounted to the passengers side fender near the battery. I made a metal shroud around the box to protect it against rain which turned out to be very necessary, because after a rainy day there was a puddle on top of the shroud from where water dripped between the hood and fender.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-02-2008, 06:28 PM   #9
Moostifer
a fool with no money
Moostifer's Avatar
started with mine on the pass. side fender well when I had A/C...
now it's on the fire wall
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 12-02-2008, 06:41 PM   #10
shrtbx
on the wheel well sounds like the ideal spot for me.
Old 12-02-2008, 11:09 PM   #11
whiskeydented
whiskeydented's Avatar
In the glovebox in my 66 chevelle, can't hear it hum with the motor running.
whiskeydented is offline   Reply With Quote
Old 12-03-2008, 02:29 PM   #12
Pyrotechnic
Here's my setup. The metal shroud is necessary to keep the box dry in this location. Also provides the mounting points for the box since the fender is irregularly shaped and has large holes in it.
Old 12-03-2008, 03:45 PM   #13
78 Chevyrado
SWEET! I'm getting an ignition box one day and thats Perfect! Thats how I want to do it! I knew i wanted to mount it to the big open spot on the fender, but was kicking around sheild ideas. I'm adding this pic to my "stuff to do pic folder" Nice work!
78 Chevyrado is offline   Reply With Quote
Old 12-04-2008, 12:27 PM   #14
Pyrotechnic
Thanks!
