SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
How many inches (bag question)
How many inches from stock would you expect to get fro this setup up front?
DROP SPINDLES, BAGS, CPP LOWER A-ARMS FOR BAGS, Right now i have drop spindles, 3" springs and stock a-arms all around, which is giving me about 5 1/2" of drop right now. how much more lower will it be putting the bags and lower a-arms on? thanks throw me some #s will the crossmember sit on the ground?
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
It's Better With Nitro
Re: How many inches (bag question)
Hey Nick. That's the front set up I have and when completely deflated, the crossmember rests on the ground. I had to install taller bump stops in case the air system failed I could still drive the truck.
Resistance is Futile
Depends on your tire diameter.....my burb has 29" tires and it sits on the fenders in the front aired out and is about 1" lower than my static truck with your same set-up. Like you said, it takes $$$ and time to do the rest
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#4 | |
SOLD
sweet, thanks vince, got any pics of it fully deflated?
#5 | |
SOLD
i have a about a 26'' tire up front
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 Last edited by 66chevy PROSTREET; 12-02-2008 at 12:07 PM. |
My tires up front are about 26" tall and if they were any taller the inner fender would rest on top of the tire with the bags fully deflated.
I'll try and take some photos this weekend (I have to put the front suspension back together). ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 12-02-2008 at 09:43 PM. |
My static drop uses a 26" tire also. It has a couple inches clearance from the ground and a couple inches clearance in the wheelwell. Like vin63 said, that would put it on the ground with bags.
SOLD
i'm in the middle of putting in the power steering kit right now, and looking at the lower a-arms, they've been takin a beat'n. my buddies baggin his 72 stepside right now with the same setup i am wanting to go with , looks like early next year i'll be doin the same for sure.
#9 | |
![]() Anyway, here are a couple of photos of my front suspension loosely assembled. The crossmember would rest on the ground if not for the wood block - I just don't have a jack with a low enough profile to slide under the truck if it is resting on the ground. ![]() ![]() ![]()
SOLD
thanks, man, thats exactly what i needed to see. it looks killer
![]() the fender extensions look great! ![]()
If you want true ground clearance with maximum drop I would look at the porterbuilt crossmember!http://www.porterbuiltstreetrods.com/products.php
2-20, 2-21 whatever it takes! |
![]() Nate even has the Newbs pushing the drop-member ![]()
#13 |
Only a Newb here , known Nate for about 5 yrs!
#14 |
yeah, just kinda a running joke here
![]() Nate does some AMAZING work!
#15 |
No problem .
#16 | |
SOLD
that would be sweet, but theres no way in hell i'm pullin my truck apart for that kinda project! i'm just lookin for a little more drop, but if i ever build another truck its getting a drop member
#17 | |
![]() ...and then this... ![]() ...then we're going to do what Chris did...wait for it ![]() ...I just don't think a drop crossmember will be necessary. ![]()
#18 | |
SOLD
#19 |
SOLD
i used some chassis tech arms i got on this forum for a good price. when the bags are deflated the inner fenders sit on the tires, and the front tube on the lower a-arm sits on the ground. i think the crossmember would sit on the ground if the tire would be able to go up higher. the benfit of these arms is that you run a full bag at ride height.
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 Last edited by 66chevy PROSTREET; 02-24-2009 at 11:02 PM. Reason: add pic |
#20 |
On the 'spindle debate' thread a guy posted saying his truck set the X-member on the ground with a 26" tire. You must be a little bigger; my 20's hold the front off the ground.
Post up a pic, I'd like to see.
#21 |
SOLD
will do,
but i think its the design of the lower a arm that is the reason. look at the way vin63's CCP arms are made compared to mine.
#22 |
Your pic came up after I read your post! Well, looks clean ..good job. Lets see it aired out.........
#23 |
SOLD
this is with the fender raised off the tire about 1/2".
#24 |
Looks cool dude.......
![]() ![]() Are you running a stop anywhere? I dont have one but need to get one in there somewhere.
#25 |
SOLD
no, not yet, i have not road tested the setup yet, i had to change my headers to some mid lengths,and i'm not yet installing them yet, and i have to finish with some sheet metal work also, then run new pipes. i will install some bump stops somewheres though.
