Old 12-01-2008, 10:56 PM   #1
67ZL1
th350 to th400 swap in 4x4
I have a '72 K20 with a t350/205 set up. I am in the process of doing a ground up and am contemplating on putting in a th400 due to the high hp and tq. My question is what kind of t-case shifter issues am I going to have? The info for the th400 that I can find says that it's a couple of inches longer, which I think it may move the shifter too far back.
67ZL1 is offline   Reply With Quote
Old 12-02-2008, 10:55 AM   #2
kwmech
Re: th350 to th400 swap in 4x4
If you are going to do a complete removal--move the engine assy. forward. You will have to redo the drivelines anyways.
now that i think about it, if you measure right, you may only have to do the rear shaft
Old 12-03-2008, 01:34 AM   #3
67ZL1
Yeah that's what I was thinking, I've got the truck strippe.d down to the frame right now and want to get my modifications done to the frame before painting. Just wanted a little reassurance from the guys that have done this, thanx.
Old 12-04-2008, 06:35 PM   #4
john@thepier
john@thepier's Avatar
I have done this conversion with a adapter plate from Advanced Adapters to mate the 400 to the 350s transfer case a company that specializes in parts for conversions. I used my stock high hump doghouse and only barely touched the stock opening in the shifter opening. No need to move your engine forward. John
john@thepier is offline   Reply With Quote
Old 12-04-2008, 11:29 PM   #5
67ZL1
So other than drive shafts the only thing I have to mess with is the t-case mounts? How did this setup work for you.
Glenn
Old 12-05-2008, 11:31 PM   #6
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
You will have to get another 205.The Th350 is 27 spline and the 400 is 32 spline and they both have different patterns on the end(350=4 bolts 400= 6 bolts).If it possible to pull out the 27 spline input and bore the case to accept the bigger input and bearing for the 400.
1-tonmudder is offline   Reply With Quote
Old 12-06-2008, 05:03 PM   #7
john@thepier
Yep 1tonmudder is right there is a tail shaft swap in the tranny as well. You use a 2wd tail shaft from a350 and cut it down for the 400 4x4 tranny. Give Advanced a call for some tech advice its free 1-800-350-2223 My set up works well and I have been using it for years. I'm currently doing a frame up so I have it out I'll snap some pictures of it this week so you can see what I'm talking about. Other wise look for a 400-205 set up there out there. The 350-205 is more than enough, just have your 350 built with good parts and be done with it. John
Old 12-06-2008, 08:52 PM   #8
67ZL1
Well maybe I should keep my 350/205 set up. I've heard lots of negative things about the 350. Guys around here are telling me to run a 400. The engine that I built is a 406 sbc, comp roller cam with Afr heads. I have no intention to do any major 4x4'n, just want something that can take a moderate beating.
Old 12-06-2008, 09:21 PM   #9
kwmech
A turbo 350 can be built pretty strong and reasonable. Extra clutches, HD sprag, shift kit etc.
