12-01-2008, 11:15 PM | #1 |
PITbut
Making heat shields??
Now that i see how dang warm the headers and mufflers get right under the cab, what material can i make the heat shields out of. would some 16 guage steel work? Aluminum? Just want something i can bolt to the underside of the cab.
Any thoughts? |
12-01-2008, 11:53 PM | #2 |
Still livin the "dream" in '54
Re: Making heat shields??
I hear that an niobium alloy would work good. Can't say on where to find it tho....
ttt Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 12-01-2008 at 11:54 PM. |
12-02-2008, 06:00 AM | #3 |
use a piece of aluminum sheet metal - about 12-16 gauge should work ok..Mount this under the cab using 4-6 pipe nipples ( 3/8" X 1" ) for spacers. Drill hole in sheet metal; insert spacer and drilll thru cab floor. Use 5/16 bolts of proper length, mounted thru the sheetmetal; pipe nipple and thru the cab floor
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
