Old 12-01-2008, 11:16 PM   #1
xpebrian
hav question
have a 1972 series 10-30 1ton cheavy truck with gasoline powerd 402 and was wandering on what the point gap should be also any tips on installing
battory isolator
xpebrian is offline   Reply With Quote
Old 12-01-2008, 11:33 PM   #2
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: hav question
Welcome to the site from still sunny as ever, will it ever cool off here, could have worn shorts today, it is December right?, Arizona! I am sure someone will chime in with the answer you need!
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 12-02-2008, 12:44 AM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: hav question
Gap to 0.019", dwell is 30 degrees. Can't help you with the isolator.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 12-02-2008, 01:44 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: hav question
Have a look here.
http://www.bcae1.com/battiso.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-02-2008, 02:48 PM   #5
xpebrian
Re: hav question
battory isolator
anybody know where i can find wiring diagram for ignatchion system pasificaly what wires go where on starter siloined
terminals marked R S any helped appreatchiated thanks alot brian
Old 12-02-2008, 02:55 PM   #6
glock35ipsc
Re: hav question
Bob
Old 12-02-2008, 05:49 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: hav question
terminals marked r s any helped appreatchiated thanks alot brian
Purple wire goes from the ignition switch start terminal to neutral start switch if automatic trans, to S terminal on solenoid (next to engine block)
Yellow wire on the other solenoid terminal ( I ) then to coil + terminal. HEI ignitions do not use the yellow wire.
VetteVet
Old 12-04-2008, 10:03 PM   #8
xpebrian
Re: hav question
battory isolator
have a 1972 series 10-30 1 ton tcheavy truck
with gasoline powered 402 it is a forword control con trol model motorhome i waqs told that it has the standard 1ton cheavy suspenchion and frame according to parts store there are two difrent sizes for rear brake shoes 13incc or 15inch was trying ti figure out what size i have so i can get parts on hand before i take it all apart anybody have an idea on what size they might be
