PROJECT 7DEUCE
![]() Join Date: Dec 2002
Got a question here a simple one..
On the front of my 72 I have a 1 1/2 sectioned crossmember,firestone bags and strong arms. The question is can I run a dropped spindle with this set-up if so how much of a drop spindle?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Got a question here a simple one..
FRENCHBLUE72,... I think most of the drop spindles are 2.5" drop. I don't see why you couldn't run them.
I think the only time there is a problem,... is when you combine dropped spindles, with the old style (DJM for example) dropped a-arms that have a "dropped spring pocket". StrongArms won't be a problem.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-02-2008 at 09:52 AM. |
yep, shouldnt be a problem... i have strong arms on my frame and dropped spindles, the do sell 3" drop spindles as well as 2.5".
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
I had 2.5" spindles, Stones, & a sectioned crossmember on my 68 before I met Porter.
PROJECT 7DEUCE
Sweet thanks guys I am so tryin to get this thing drivable soon I am gonna do drop members but not untill after the truck is alomost complete. I have not drove this truck in almost 9 years so ....
#6 | |
3DrDwn--the 'burb not the band
Obviously you know what's best for your situation but I'm the type of guy that starts with the foundation and then builds on top. That is why I have put most of my resources into my chassis/drivetrain without even looking at body/int items. My bare frame w/ f+r DM's is documented in my build in my sig. Check it out if you like and good luck with your project. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
PROJECT 7DEUCE
Thanks guys for the imput and josh I hear ya but with work slowin down and me wanting to get this thing on the road its gotta stay the way it is for now cause im getting into the i wanna do this and this and this and the list never stops...
