Old 12-02-2008, 01:51 PM   #1
1987SierraClassic
Power Window Motors
Does anyone know how long it REALLY takes to swap out the power window motors in an '89? I have new motors and the shop says it takes 8 hours to swap out the window motor on ONE door. I can't imagine it takes that long. It didn't take me that long to swap out the front axle and all four springs (without air tools)!
Any advice is appreicated!
Thanks!
1987SierraClassic is offline   Reply With Quote
Old 12-02-2008, 04:23 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Power Window Motors
http://73-87.com/7387garage/interior/winmotor.htm
Malo83 is offline   Reply With Quote
Old 12-02-2008, 04:32 PM   #3
1987SierraClassic
Thanks, Malo83! Good info.
How difficult is it to get the regulator out of the door and how long did it take you to do both motors?
Old 12-02-2008, 04:41 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
I haven't done mine, but I need to, they are super slow
Old 12-02-2008, 05:08 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Inexperienced about 1.5hours.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-03-2008, 01:40 PM   #6
1987SierraClassic
Thanks, Captkaos!
I guess 8hrs is a little off the mark!
I'll probably attempt them myself.
Thanks everyone for responding!
Old 12-03-2008, 01:55 PM   #7
Captkaos
Captkaos's Avatar
No problem, that's PER window BTW.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-10-2008, 01:54 PM   #8
1987SierraClassic
One more question...
Is it difficult to remove/replace the glass from the regulator channel?
Old 12-10-2008, 03:00 PM   #9
Captkaos
Captkaos's Avatar
Roll it all the way down, make you some clearance around the rear support (I unbolt it) and slide it back to the notch. It can be a pain.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-10-2008, 04:29 PM   #10
flamingbig10
6.0 powered square
flamingbig10's Avatar
if you want to make it really easy then cut holes at the bottom of the door witch gives you access to the bolts and then add speakers
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-19-2008, 01:49 PM   #11
1987SierraClassic
Thank you all for the replies...
I'll give it a go!
Old 01-02-2009, 05:52 AM   #12
86 silverado short
I just changed mine out on my 86 silverado. It took about 2 hrs on each door. I also changed out both lock actuators. It was alot easier with help. two person job..
86 silverado short is offline   Reply With Quote
Old 02-15-2009, 03:02 PM   #13
Joemt
Where is the best source for purchasing the power window motors and door lock actuators????
Did any of you use any sound deadening material on your doors when you re assembled???? Source???
Thank you,
Joemt is offline   Reply With Quote
Old 02-15-2009, 03:23 PM   #14
86 silverado short
bought mine at auto zone. They were about $55.00 each with life time warr. I also made some liners out of thick mil plastic and some thick paper used some spray glue to glue them together. Not to help with noise but also dust and air. seem to be working good. I just installed them yesterday.Hope this helps.
