its all about the +6 inches
![]() ![]() Got the 425 and the TH350 in the back of the GMC...along with a folding engine hoist and my engine stand. She is sitting pretty much level now. ![]() Taking them to the shop tomorow, and as soon as we are closed and all cleaned up, I'll be taking them in and having the tranny looked at (if the tranny guy shows up...he's kinda undependable) and another guy is going to give me a hand with removing about 6 or so broken exhaust manifold bolts. If it all gets done tomorow, (not likely) then I will be dropping the engine back in on Sunday. I got the frame rails drilled for the motor mount towers, frame rails all painted nice and pretty. Taking the towers in to the shop too, going to take the plazma cutter to them and re-do the hole thing that I kinda butched up. ![]() If all goes well, she may be rumbling (uncorcked) in a week or two! Heck...it might even move under it's own power too! It could happen |
For a guy with no place to work and limited funds, you sure get a lot done! We should all be so dedicated about our passions in life. Good luck with the project. Thanks, Lyman.
looks like its coming along great Andy..get that thing rumblin and she'll be road worthy in no time
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
Fabricate till you "puke"
Woohoo! I love it when a truck come together
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#5 | |
Your right about the no place to work and limited funds. I don't think I have dropped a penny into that thing for about 2 maybe 3 months. It has all been just labor. And let me tell you....it's getting COLD out there.
![]() I do have to say thanks to all the support I have been getting here...and an honorable mention to fine69 for an extended loan on the engine hoist and all the other help he has been. |
After seeing that truck, it makes me want to build a truck with a caddy big block too. Now I just have to figure out how to get a caddy engine for cheap without having to take the car with it
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Heh heh heh... Now the only question is...am i a good influence...or a bad one?
Don't forget in Cali you have to pay all the back registration when buying an unregistered vehicle. |
#8 | ||
Nice Work andy!
Good going Andy.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
Good for you Andy.
Jason...you mean like this where the towers are actually bolted in;
![]() Then a goofy lookin guy stops to pose... ![]() And then actually bolting the engine in like this... ![]() Is that what you mean? ![]() (It's bolted in now) |
#13 |
Man any time I try to bring you down man, you gotta go and show me up! Hhhmmmm, I know, I don't see the tranny bolted up to it. LMAO!! Now, it's looking good Andy!
#14 |
heh heh heh
Your right...no tranny yet. the tranny guy never showed, which was a good thing becouse my funding for the seals and filter kit vanished. Oh well...at least I'm done toting engine hoists around. |
#15 |
But now the bummer part, you have to be under the truck to get that tranny in. I like to drop engine + tranny at the same time if I can.
#16 |
You wouldn't want to when the engine is as big as this. Plus, i had to persuade the motor mounts into the towers...I didn't trim them enough to drop straight in.
Things to remember next time I do a swap like this. (If I am somehow able to keep the GMC...it'll get Caddy power too) |
#17 |
Ya the engine is big, but you have no front clip.
#18 |
Yup. Fine69 hooked me up with a couple grills instead of my kerfagled one. I still need a couple fenders, but I'm not in too much of a hurry on them. I'll use the bondo filled ones for now. I'll be keeping the greenish hood that was on the longhorn when i picked it up though. Even though it has some rib rust out, it is 10 times straighter than the GMC's.
#19 | |
#20 |
kerfagled? sounds like something i'd say after about 6 beers.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#21 |
Hhhmmmm, fenders. . . . .
#22 |
Looks like the bed needs a little work......why not test drive your Cadihorn to Tucson to pick up my spare Longhorn bed. It'd be a lot warmer working conditions here. LOL
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
#23 |
that is to wierd my LONGHORNILLAC was the same color from the factory what year is yours??? by the way mooneyes said you liked the 500 emblems and wanted some I am trying to get another set made for my longhorn but the guy isn't to motivated. my dad bought a 500 cad years ago (the one the emblems are on) and the guy was planning on puting them on a 6772 so he made them but he said it took to long and he wouldn't do it again
67 chevy short step 2wd 427 71 chevy short fleet 4x4 396 72 gmc jimmy 2wd 377 71 chevy blazer 4x4 454 69 chevy longhorn 5.9l cummins 72 chevy 400 2wd custom camper 67 chevy lwb 4x4 454-in pieces 67 chevy panel soon 4x4-400 67 gmc dump 4x4 1 ton-305 WTF!! 72 chevy 3/4 ton 4x4 burb 350 70 chevy panel 2wd 302 5 speed tko "THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!! |
#24 |
My other Love
does that lock on the caddy motor qualify as an anti theft device?
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#25 |
I think it just means that she's "locked down"!!!
