12-02-2008, 03:44 PM | #1 |
700r4 tranny question
how hard, and what would it take to put a 700r4 tranny in a 76 k10? or should i just go with a thm400? has a "good enough" working 350 in it now. i plan to rebuild the motor so I want something a little beefier behind the sbc.
12-02-2008, 03:48 PM | #2 |
Re: 700r4 tranny question
It is not that difficult. The cross member will need to be moved back, but the most important thing is to get the TV cable adjusted correctly. I did this change myslef a couple of weeks ago. I went from a 350 to a 700R4, I love the low first gear in the 700R4 and my 3.73 rearend likes the overdrive.
1976 C-10 shortbed 2wd (work in progress) Mods: Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier http://www.cardomain.com/ride/3136537 |
12-02-2008, 04:50 PM | #3 |
not sure what rearend gearing i have, it is a 14 bolt. would the 700 be better than the 400 as far as off roading and 4wheeling be concerned?
12-02-2008, 04:55 PM | #4 |
In my opinion, if all you are worried about is off roading and 4 wheeling and you have a 350 in already, I would just stick with it. If you are staying on pavement, I would go with the 700R4. Just my 2 cents, I am sure you will get different opinions on here.
12-02-2008, 06:40 PM | #5 |
Georgia Boy
You would have a serious low gear in 4WD low, that's for sure! =)
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
12-02-2008, 10:16 PM | #6 |
my question is on the same thing, i have a 700r4 in my truck now that is junked, i would like to drive my truck to the mud and trails on the highway, then when i get there have something that is dependable!! I have a 400t with all the driveshafts and axles and the t-case, what would you do??
IMO.....if you are gonna spend more time in the dirt use the 350t or a 400t otherwise, i think the 700r4 is the way to go......i hope you guys could give us both opinions!! Thanks guys this forum is great!!
'04 Chevy Ext. cab SB 4WD 8.1 Allison Daily Driver '84 Chevy 2wd 1 ton CCLB dually needs lots '72 Chevy LBSC K20 |
