Rides like a train
Greetings
I have a 72 K10 with about a four inch lift. The problem is it rides like a train. Will pulling two of the load springs out of the front smooth out the ride ? I will need to re arch the spring to bring it back to the four inch lift. Local shop said 250.00 bucks. Will that be money well spent ? Thanks |
Re: Rides like a train
Do you know what brand and type of leaf springs you have now? I would think that they would sag over time if you removed 2 of the leafs. Do they have 5 leafs now?
I have never used them, but a couple of the companies make ez ride or soft ride springs. I think you could buy a whole new front leaf pack for about 350-400$. That may be money more well spent. Lynn |
Don't know what type. Not here to look at (youngest son has it). It has at least 5 leafs. The shackle bushings are shot and need to be replaced. Some of my 4X4 freaky friends say to drop two leaves and it will make a large diff in the ride
I don't have anything to compare but my 85 Ford F150 with a four inch lift. It has coils on the front and rides a lot better. Will have to look around thanks |
I put a set of soft rides on a Jeep with a small block in it,if you wheel it hard those springs are no GOOD they can colapse,if its more of a everyday driver they work great.
I'm a poor spectator
How much do you want to spend?? Alcans will run just shy of a grand for custom springs but ride nice.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
dump the lift and oversized tires going back to stock it will improve the ride
#7 | |
![]() Join Date: Aug 2008
Maybe you truck rides more like an empty dump truck? Those worn out bushings are not helping the ride any. Did the P.O. install a lift without replacing worn parts? not the smoothest move, IMO. I have a 71 Cheyenne I am parting out that has Superlift 4" springs and it rode the same as stock. (Sorry, springs not for sale separately, at least at this point. I am going to try and sell the rolling chassis complete. IMO, taking out leaves will be a temporary fix. It will ride smoother, but they will start to sag, especially if wheeled hard. I would look into some different springs. Last edited by WIDESIDE72; 12-03-2008 at 10:50 AM. |
mine stops like a train
I guess it's subjective. My Ford F150 with about the same lift rides much better. Spent more than I had on the 5.3l install. Will have to live with the bounce for a little while. I have a leaky NP205 that will get my time and money this month.
Thanks |
This man speaks the truth.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
