Old 12-02-2008, 07:25 PM   #1
jmedero
jmedero's Avatar
picked up an 84 parts truck
Ok so I got an 84 parts truck today for $75!! No engine or trans, and front fenders, hood, doors and bed are gone. A couple of questions I have as to what I can use for my baby.
1. with the front suspension what can I actually use to convert to a 5 lug disc?
2. the rear is a leaf spring set up and mine is a coil set up. Can I just swap out the "guts" of the rear to make my coil rear housing a 5 lugger?
3. booster and mast cyl will just bolt in place or do I need modifications?
I plan on junking the rest of the cab, dash, frame and front grill support. Is there anything else I should think about taking before I get rid of the rest?
jmedero is offline   Reply With Quote
Old 12-02-2008, 08:54 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: picked up an 84 parts truck
No you can't swap the guts from the rear end. You can get some weld on perches for the rear end and do it that way but you will need a kit also for the panard bar. It is easier to get a rear end from a 71 or 72. If your truck is a 63-66 then you just need the control arms and the rest of the steering componants along with the steering box. If it is a 60-62 then you will need the who crossmember. The power brake booster will need some fab work don't to where it connects to the pedal. The rest will bolt in with a few holes to drill.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-02-2008, 08:57 PM   #3
1966gmc
Why does it taste purple?
1966gmc's Avatar
Actually you can just swap out the ball joints to 84 joints in your original control arms if I remember correctly.Thats the way im planning on goin this winter when I attack the 5 lug conversion.
1966gmc is offline   Reply With Quote
Old 12-02-2008, 09:05 PM   #4
steverino66
SCORE!
1. I used an 83 and swapped over the entire crossmember - have to drill a couple of holes, but it will bolt to your frame, a-frames and all - there are a couple of members here who have power steering adapter kits if you want the power box.
2. That rear is wider - you can get replacement 5-lug axles from CPP; some have re-drilled the 6-lug hubs for 5-lug, but others don't advise doing that
3. With slight modification of the mounts, the booster and MC will bolt up, the pedal rod has to be lengthened a couple of inches; I've seen kits for that but I just had the old pedal end and the newer booster end welded together to the right length
I'm sure I've left out a lot of small details, but it's all do-able. I took the whole tilt column, power steering lines, any brackets/hardware for all the above (84 is metric, older truck SAE)
steverino66 is offline   Reply With Quote
Old 12-03-2008, 01:20 AM   #5
jmedero
jmedero's Avatar
what would be the reason of doing the whole crossmember instead of just the parts swap?
So if i did ball joints of a 84 on my current arms the rest will bolt up?
I will def be taking the power st off of the truck and using it. Like I said before the engine is gone so no pump or lines but the box is there.
Old 12-03-2008, 11:07 AM   #6
Chevy Fleetside
So what year is your truck?
Old 12-03-2008, 11:31 AM   #7
jason65
Registerd User
jason65's Avatar
I put 84 balljoints, spindles, etc and that rear axle kit from cpp on my 65. Now the rear end is way to narrow when looking at the front. I guess I'll just run a different offset wheel on the back. I don't know that if you swap the cradle you will have the same prob of not.
jason65 is offline   Reply With Quote
Old 12-03-2008, 12:01 PM   #8
jmedero
jmedero's Avatar
Mine is a 66 lwb and the parts truck is an 84. So should I do the control arm swap or just the ball joint?
Old 12-03-2008, 12:07 PM   #9
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Keep the drag link from the 84 and install it so you dont have to worry about tie-rod ends matching up.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 12-03-2008, 02:10 PM   #10
gulfcoast66
64-66 CHEVY JUNKIE
[IMG][/IMG]Heres a pic of the idler arm istalled.
Old 12-03-2008, 03:15 PM   #11
jmedero
jmedero's Avatar
thanks gulfcoast66. Do you have any more pic's? Advice?
Old 12-03-2008, 03:58 PM   #12
Chevy Fleetside
If it is a 66 then you don't have to swap out the whole crossmember. You can use your stock control arms if you want. The later control arms used rubber bushings for a smoother ride. I say don't drill for the idler arm untill after you install the rez kit for the power steering box. That is about all the pictures I have for now. You can also use the sway bar. You will need the mounts that are rivited to the frame also.
Old 12-04-2008, 08:15 PM   #13
jmedero
jmedero's Avatar
Talking Re: picked up an 84 parts truck
Can I use the tilt st wheel out of this truck? Is it worth losing the classic feel?
Also is an automatic truck and Mine is stick. I will be changing to automatic so..... heck i dont know.
