HERE.......Somewhere
What would yall do????
i got a very or moderate rust issue and can get my light back on tight again what will work? Its clearance lights
HELP!!!!!!!!! I dont want the rest to rust into chunks
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! |
Gone to greener pastures
![]() Join Date: May 2007
Re: What would yall do????
Quentin,
Just give the dang thing to me & buy another truck. I'm always glad to help a buddy.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
His name isn't Quentin.
#16876
QUOTE=Shane;3005370]His name isn't Quentin.[/QUOTE]
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
I need to get it bolted down some how
please guys help me out
I'd help, but to be honest, I'm not exactly sure what you are asking?
can you maybe explain it a bit better.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
2 part clear epoxy for wal-mart. It is in the auto section, put some rust converter, on there and let it dry before you do the epoxy.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
what is a rust converter and what color does it come in?
rust converter, wal-mart sells it too. It stops rust in it's tracks. I personally use POR-15 but there are many others, even naval jelly may do the trick (in automotive dept)
do you spray it out of a can or use a paint brush???
#13 |
this issue might just answer where is the water coming from in your leaking post
#14 |
I brush the POR 15 on, the stuff Wal-mart sells you can buy a spray.
#15 |
Here is the pic
Can it be fixed having the rust cut out and weld in new metal? I used the rust converter and took it back tonight the crap didnt work it was like a clear coat. Is there any better kind like maybe NAPA or Advance autoparts?
#16 |
You're absolutely right.
Just think "brain fart" & cheap whiskey.
#17 |
Cut it out, weld in new metal. There is no miracle product for this application, if it were in the bed of your truck then you could just slap some POR 15 on it and it would block the rust from air and eliminate it spreading but breing on your roof, I don't see you being able to sealing off the light and keeping water out of the cab.
#18 |
For a cheap fix:
Use the rust treatment.This stuff isn`t paint,it`s a chemical rust neutralizer.Permatex sells it in spray and brush.It turns rust black and leaves a clear glaze.Try bonding (JB Weld,epoxy) a piece of metal behind the roof skin.Drill a hole and run a sheetmetal screw in first,before you cut it down to a small piece.That way,omce the bond is cured you can run the screws in without worrying about breaking your piece loose. OR...use little stainless nuts & bolts & washers(flathead or ovalhead machine screw)and assemble the light off the truck.Then,use a real good caulk or glue that will seal it and bond it in place.I have an excellent caulk I use called Geocel.It`s a tri-polimer urethane caulk and it doesn`t let go once it`s cured.Seals and lasts better than any caulk.
#19 |
Rust converter is just that "converter" Since your roof is white, I would cut the metal out that is rusted and weld in a patch panel. Prime and paint the roof. It could easily be done in a weekend if you have the ability.
#20 |
You could try nut-serts.
#21 |
