heater box replacement
Hey guys..
New to this forum as I used to have a 72 Cheyenne, but now have an 86 El Camino. A few of you guys have these cars and now some advice. My heater box is leaking (when I turn the heater onl). I really haven't inspected where the leak is coming from, but if worse comes to worse, how difficult would it be to replace the heater box on my ride? Any advice is appreciated. |
You get what you pay for
![]() Join Date: Dec 1999
The heater core is what's leaking. It is inside the box. Never changed one on a El Camino, but it should be basically the same as a truck. It involves removing the nuts which hold the box to the firewall to gain access to the core. If it's like our trucks, there is nuts on the engine bay side, and one under the dash toward the passenger door.
Mike 1985 Chevy C-10 |
Late model A/G bodies are notorious for leaks around the a/c heater box. If it's the core leaking you must remove the box to get to the heater core. If it's the box that's leaking, remove it & scrape all the old sealant off then put new putty type sealant back on. I would recommend replacing the heater core if you remove the box whether it's needed or not because it's a pain in the arse & would suck to do the job & then a week later have the heater core start leaking & need to do it all over again.
I'm happy to report that all it was some bad mechanic that didn't tighten the hose clamp after the nipple of the heater inlet. Simply moved it 1/4 inch and tighten and no more leaks. Yes! Thanks guys for your help.
Will |
Don't you just love it when it's something simple?
speaking of clamps. I found a fuel leak on my truck this weekend. It was the rubber lines from the frame to the pump. They were old and one had a very tiny hole in it. I replaced them both, but I had one hell of a time getting those damn squeeze clamps off of there. Anyone else hate them? I like the screw type hose clamps.
Anyway I replaced both lines and all the clamps. Hey Mike arent you worried about getting a hose leak under the steel braiding? It must make it harder to pin point the location. Just curious if youve ran into that problem yet.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
Eddie,
my heater hoses are the blue silicone like they use on big rigs. It should stand up for a long time. I hope so anyway. No problems so far.
