Old 12-03-2008, 12:31 PM   #1
Texasdeere
Texasdeere's Avatar
3 speed column to 4 speed floor
I don't know much of anything about the 55-59 trucks. I was wondering what would be involved in changing the column shift to a floor shift. Is there a removable floor hump section? Also are there any late model overdrive manual transmissions that would bolt in relatively easy?
Texasdeere is offline   Reply With Quote
Old 12-03-2008, 09:05 PM   #2
55dude
55dude's Avatar
Re: 3 speed column to 4 speed floor
what motor do you have? t-5 is about the easiest swap. do a search been done many times.
55dude is offline   Reply With Quote
Old 12-04-2008, 12:09 AM   #3
Texasdeere
Texasdeere's Avatar
I am looking at buying a 59 with a 235 and 3 speed column shift.
Old 12-04-2008, 10:24 AM   #4
54 jimmy
54 jimmy's Avatar
they make a kit to change the three on the tree to a 3 on the floor kit. i think hurst makes it and it is fairly cheep too. might be b&m.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-04-2008, 01:15 PM   #5
solidaxel
solidaxel's Avatar
Hurst
I have used swap meet 4 speed shifters and only used the ones for the two arms and not the reverse so your options are open,
If the gear box is bad you may look into a saginaw camaro 3 speed it should fit right in place of your 59 3 speed box. you have many options by not having a rear crossmember to worry about
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-04-2008, 04:45 PM   #6
petey
My experience with transmission swaps is you may run into problems with tail-shaft length. And the transmission crossmember. Of course, the driveshaft can be shortened and the crossmember modified or changed.Then worry about a shifter.
petey is offline   Reply With Quote
Old 12-05-2008, 01:48 PM   #7
solidaxel
solidaxel's Avatar
Does your truck have the rear motor mounts on the bellhousing?
LS 3 4L70E
Old 12-05-2008, 10:07 PM   #8
Texasdeere
Texasdeere's Avatar
I haven't looked at the truck in person yet. So I have no idea what it looks like underneath.
Thanks for all the info eveyone!
Old 12-06-2008, 05:59 PM   #9
Gene Sharp
a muncie or Warner T 10 or super T 10 should be pretty much a bolt up
and you can buy a hurst shifter stick with a bend to clear bench seat
makes for a fun driveable package
and with a highter geared rear you can use 1st three gears around town and 4th on the highway
If you do a V 8 swap a v 8 bell housing for the early years will let you retain stock cross member and clutch and everytihng hooks up
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 12-09-2008, 09:17 PM   #10
Cops053
Cops053's Avatar
Mr Gasket makes a pickup truck 3 speed floor shift conversion kit for Chevs part # 7667A. Just put one in my sons 67 C-10 was easy to do. Purchased it at Ato Zone for $69.99 plus tax. Hope this helps you
Cops053 is offline   Reply With Quote
Old 02-22-2009, 02:36 PM   #11
Texasdeere
Texasdeere's Avatar
Yes it does. I am definitely not liking the column shift. I was considering a stealthy automatic conversion, but that is kind of difficult with the 235 6 cylinder. Before I take the V8 with Auto plunge I may try a floor shift conversion.
Old 02-22-2009, 02:45 PM   #12
Texasdeere
Texasdeere's Avatar
Thanks, I may try that one.
