12-03-2008, 04:44 PM | #1 |
front shock mount question
I was doing a tune up last night and I noticed that the upper shock mounts looked like they were welded all the way around on both sides. It almost looks factory but I don`t know if it is. Part of one weld chipped off at some point. The stud is there and doesn`t appear to be welded. Is this normal? If not I`ll try to get some pics later.
Anthony |
12-03-2008, 07:50 PM | #2 |
www.73-87chevytrucks.com
Re: front shock mount question
It is not normal. Normally there is just a stamped hole. Someone did repairs to the frame. The stud was bolted on from the factory.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-03-2008, 09:11 PM | #3 |
Thats what I was afraid of. I`ll have to take a closer look at it to see if it`s safe. I might even call the PO and see if he can add any info on it.
Anthony |
12-03-2008, 10:19 PM | #4 |
I had to do that repair on my 1978 stepside. The shock stud came loose and egged out the hole. I never had any problems after that. What Harley dealer do you work for? I am also a Harley tech.
12-03-2008, 11:27 PM | #5 | |
Well I started out at Fairfield HD and moved with then to the current location where it was Vacaville HD. Then I went to Sacramento HD but got laid off last December. I`ve worked at 2 aftermarket shops this year and they suck. I haven`t worked in 2 weeks. Well, not at the shop anyway.
Anthony |
12-03-2008, 11:35 PM | #6 |
Sorry to here that you haven't been working. It is getting slow at our shop but they seem to have enough work to keep us going so far. My truck is a 1984.
12-03-2008, 11:38 PM | #7 |
when your the new guy you go home first if there isn`t enough work for everyone. I`ve been doing it since 2002 and I`m ready for something else and just keep bikes as side work. I got enough regular customers to kep some money coming through.
Anthony |
12-03-2008, 11:43 PM | #8 |
That is the good thing about side work, someone always wants their bike worked on. if the repair on your shock mount was done by a good welder it should be fine. I never had an issue with the one I repaired.
12-04-2008, 12:28 AM | #9 |
Sb 400 club
my old 65 had the egging losse shock mount. The weld is better then the washer repair.
As stated above ^^^^^^ if it was done by a good welder your all set!
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
12-04-2008, 12:47 AM | #10 |
Yeah I make pretty good money on side jobs. I`ll have to take a close look at the welds. I noticed it last night and light wasn`t on my side. They looked ok except for the driver side did have a piece of the weld broken, maybe a 1/8-1/4" section. I need to take a good look at it and if it`s questionable I`ll have it redone.
Anthony |
12-04-2008, 03:22 PM | #11 |
This is a common fix as indicated. If it was welded right, it should be fine.
12-04-2008, 04:19 PM | #12 |
Parts and more parts
COMMON GM shock/frame stress problem. I have done quite a few of those and the trucks are still running great.
