Old 12-03-2008, 05:21 PM   #1
trenchwarfare
Leaf spring shims
I messed up my rear end a while back. I got it as close to the proper angle I could and rewelded it, but it is still off about an eight or a quarter. Where can I get some cheap 1/8" or 1/4" shims.
____________________________________
trenchwarfare is offline   Reply With Quote
Old 12-04-2008, 11:47 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Leaf spring shims
Check your local 4wd shop, or Summit Racing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-04-2008, 10:40 PM   #3
crazy longhorn
Fabricate till you "puke"
Yup, local suspension shop.....you should be able to ge 1, 1 1/2, 2, 2 1/2,3, & 4 degree shims (brass are the best), as they wort spit or corrode like aluminum. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
