Old 12-03-2008, 05:28 PM   #1
Custom 68
Custom 68's Avatar
cpp modular spindles
http://www.classicperform.com/NewPro...op_Spindle.htm
Have you all seen these? It has been posted on here a few different times (including by me) talking about how the front track width is increased by the drop spindles and converting to disk brakes.
I dont know if this is an "easy" fix for this problem it reads like it would bring the track width back in.
with my current setup I will rub my front tires on a dip I am only lowered by the drop spindles.
Any thoughts?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 12-04-2008, 04:28 AM   #2
Raguemoe
Junior Member
Raguemoe's Avatar
Re: cpp modular spindles
I have them on my 67. They made the rotors rub on the A-arms (we had to grind a little to make them work)
Raguemoe is offline   Reply With Quote
Old 12-04-2008, 11:12 AM   #3
Custom 68
Custom 68's Avatar
Thanks, I assume they dont change any geometry I dont believe there is a way for them to do that. I would rather go a different route but everything else gets expensive real quick.
Dave
Dave
