Old 12-03-2008, 08:46 PM   #1
slepysal
slepysal's Avatar
Brain fade : brake line fittings question
What size fittings are used when spliting the brake lines?
I want to get what I need for my master cylinder swap. So what size plug for the "T block" and what size for the coupler or union, as well as any other fittings? I cant remeber.....
Chief I know you can help
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-03-2008, 09:12 PM   #2
502tripower
502tripower's Avatar
Re: Brain fade : brake line fittings question
Not sure what you are asking. If you are swapping out to a duel master you should be using a proportioning valve not a "T". The proportioning valve will have a place for 4 brake lines to attach. One for each wheel of the truck. You can either order this from one of the many aftermarket dealers or at your local parts store.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 12-03-2008, 09:17 PM   #3
slepysal
slepysal's Avatar
I was going to just plug the t block that splits the front-rear brakes, and then tie the rear line into the porportioning valve via a union
Old 12-03-2008, 09:40 PM   #4
62 short step
62 short step's Avatar
It depends on what size the brake lines are, 1/4 or 3/16.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 12-04-2008, 03:00 PM   #5
slepysal
slepysal's Avatar
ok 3/16 . The union should be an inverted one right ?
