12-03-2008, 09:02 PM | #1 |
Need some help from bucket seat gurus!!!!
Here is my situation I am in the process of making some attachment brackets for bucket seats that go on the under side of the cab floor. The ones in the pic below were made by this guy while I waited. The final ones should be near exact. I took the original ones off a bucket seat cab without doing much damage to the cab that was a complete truck to be sold. Now for my problem. I need one more bracket that I could not get off of this truck without really messing up the cab. It is the long brace that stretches from the bolt hole on the front inside of the drivers side bucket seat to the front inside bolt hole of the passenger side. This is probably worded funny but I hope you get the idea. Is there anybody out there who has a trashed factory bucket seat cab that could cut out this brace for me. I know some one had a floor section awhile back, but I missed it. You would not have to remove the brace from the floor itself, I can do that. Just cut out the entire floor section brace and all. I think it is about 18 inches. I will be making several sets of these Just incase there are other fanatics like me out there. Sorry for the long post…..Jason
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 12-03-2008 at 09:03 PM. |
12-03-2008, 10:32 PM | #2 |
Re: Need some help from bucket seat gurus!!!!
When you make these what type of money are you looking for, I need a set for my 4x4 cab- just got a set of buckets and console for it. LMK thanks, Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-03-2008, 11:52 PM | #3 |
Moderator
Jason- I would also be interested in purchasing a set from you. Thanks, Scott
12-04-2008, 03:15 AM | #4 |
I am not sure on a price yet, but I will keep in touch when I find out.
72 Cheyenne Super 80 Silverado Blazer 2wd |
12-04-2008, 06:11 AM | #5 |
Jason,
Do you know if a Blazer floor is the same? Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
12-04-2008, 06:38 AM | #6 |
You should be able to use a trashed K/5 floor.That would be great to make these up.I had the same idea,just needed the donors to model after.I think you`re on to something and please let me know when these are available.I need a set for my one project.
12-04-2008, 07:34 AM | #7 |
Not sure if I'm thinking of the same part as mentioned above, but if your talking the brace for the forward seat mounts it may be already made by Tri-pro since they make the entire cab floor and that bracket is part of the floor
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-04-2008 at 07:34 AM. |
12-04-2008, 12:50 PM | #8 |
That’s a good ? My first thought was yes, but then I remembered that a blazer has a different seat bracket on the passenger side. I would think that the brace would be the same though because it has to follow the same contour of the floor. Maybe just the holes in the brace would be different.
Jaros……. I don’t think this piece is made is made. On a bucket seat cab there are 8 mounting location for the seats and on a bench seat cab there are only 4. On buckets only 2 of the 8 (the outside front) use the same mounting location as the bench seat. The other locations are different and use specific braces welded onto the floor.
12-04-2008, 02:05 PM | #9 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-04-2008, 09:01 PM | #10 |
Jason
I'm pretty positive the K5 is the same for that front brace. I had planned on removing it from my rusty Blazer shell and those little braces too for my bucket seat 72 project cab. I guess I would also be interested in buying these little ones too in case mine are too rusty or difficult to remove. Maybe we need to get an original front brace for a pattern to have that made also??? A complete factory look bucket seat install kit would be just the ticket for these trucks. That is always the first thing I look up under the floor when I look at the bucket seats especially if the glove box label doesn't list them as factory. Good luck, Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" Last edited by HOTFUN; 12-04-2008 at 09:03 PM. |
12-04-2008, 09:25 PM | #11 |
Got big-block?
Hi Jason,
Put me down for a set when you get the produced. Thanks, Casey
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
12-04-2008, 09:26 PM | #12 |
Mark,
If the one on your blazer is rusty,that migh be a good one to take off, Rust is ok, as longas it is not too rusty and can be removed intact and not all bent up. The guy who made those small ones said he can make anything, so all I need is that long front brace. If you can get if off intact I will give you a complete set free when I get them made......Jason
12-04-2008, 09:36 PM | #13 |
I just reread your post and I realized I must have not made my self clear in the 1st post. That is my intention, to make all of them so as to make available the entire set of five for whoever needs them.
12-04-2008, 10:13 PM | #14 |
Yeah I thought you were looking for one factory one for your truck. I will be getting my Blazer apart in the next month or two as I need the drivetrain for my 67 project frame. If someone comes up with one here that's fine otherwise I will send you mine when I get some time to roll that body off. Between work and some other investment projects and this cold weather I have had little time to work on my cars.
Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
12-04-2008, 10:16 PM | #15 |
You might also want to try and document the location of those small brackets especially pictures of factory untouched as they will be a perfect installation aid for the set of brackets. Not too many of those trucks left the factory and it was not till several years ago I even knew what to look for on factory bucket seats.
12-04-2008, 10:58 PM | #16 |
Please add me to the list .... I need a set for my truck as well.
[B]72 Cheyenne SWB |
12-05-2008, 02:33 AM | #17 |
This seems to be mostly a discussion about the brackets above the floor, but don't forget the ones under the floor that keep the bolts from pulling through in a wreck...
I don't want to be a killjoy, but spread the load. |
12-05-2008, 03:39 AM | #18 |
Always on the hunt...
This thread/discussion is pertaining only to the brackets that you mention, the one's under the floor pan.
12-05-2008, 06:07 AM | #19 | |
Jason, in your first post you had mentioned thinking this main support brace was only 18" or so in length, but if you take a look at each end of the brace you will notice it is welded at both of the main cab floor supports which are about 46" across. After taking all of the time to do this the right way, you would want to make sure that you get a full width support so it connects at both floor pan supports for that factory look. Good luck on the hunt, Mel |
12-05-2008, 06:34 AM | #20 |
Here are a couple more pictures from the top side view, I have marked all 12 of the factory bucket seat (truck) 5/16" mounting bolt holes with a blue X. Take a look and note how the factory filled the seven original unused bench seat mounting bolt holes with 5/16" phillips/truss headed machine screws.
12-05-2008, 06:53 AM | #21 |
Here's some more pics for you, off of a '72 Jimmy. It looks to me that if you drill the cross brace and weld in the square nuts, it would look original
My photobucket just went down I'll post up more, OK back on line. Why GM put 3 square nuts there, I don't know, as only 2 are required Wes, in your first set of pics, third and fourth pic, does that just look like a doubler plate on top of the crossbrace? Mine looks very similiar, but w/o that top pc.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-05-2008 at 07:20 AM. |
12-05-2008, 01:57 PM | #22 | |
......Jason
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 12-05-2008 at 02:08 PM. |
12-05-2008, 03:51 PM | #23 |
SWB 4x4 Collector
Jason, I have this brace you are in need of that is already cut out. Randy (Teeitup) sold it to me a few years back, and we haven't tackled this other cab yet. If I send it to you, you will send back a complete set including this bracket for a bucket seat floor? I am currently preparing my final exhibition in college for graduation next saturday. After that, I can get home and send it to you. I am away from the house. I would be down to send it to you for all the correct brackets though, and to help out the good cause. Let me know. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
12-05-2008, 04:35 PM | #24 |
Trevor, That would be awesome. This is out of a truck too and not a blazer correct? That way I wont have to worry about figuring out any modifications without having a truck to go by. I will send you a complete set of the five braces + whatever else is included in the kit.
The copies in the pic above were done by hand, but the final ones including the one you supply will be done by a computer plasma bla bla bla thing. I will PM you my mailing address. I will pay for the shipping too. It should not take long to get these done because I am wanting to get them done before I drop the engine and trans back in ……..Thanks Jason
12-05-2008, 06:49 PM | #25 |
i would be intersted as well
