Old 12-04-2008, 03:30 AM   #1
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
list of bulb #'s and qty in my dash....
Sorry if this has been beat to death but I couldn't find any info.
What I'm after is the number and type of bulbs that are all the lights in my dash. I wan't to include every bulb even idiot lights.
Vehicle is my 1989 GMC sq. body dually non tach dash.
I need the info for two reasons:
1) my High Beam indicator is out and I'm constantly getting flashed for leaving highs on and I want to fix it. Also the upper left of my speedo will drop out occasionally. Since it is fairly labor intensive my plan is to just put a new bulb in every spot so that I can be done with it. Yeah i know there's a chance of a bad "new" bulb but this still seems like a good law of averages thing.
2) in other vehicle aplications ( yeah mostly imports and motorcycles) I converted the guages to LED's. this would be the best for me cause I really like the look and longevity of LED's. soldering and voltage matching isn't really an issue but I'd like to plan way ahead to minimize my downtime since while it's not my daily I do drive it alot.
Thanks in advance,
Josh
PS the bezel had an old wood kit on it and I'll be doing something to fix the look of it.
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 12-04-2008, 07:02 AM   #2
cjracing15
cjracing15's Avatar
Re: list of bulb #'s and qty in my dash....
bulb # is 168 I will count them later today for ya.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 12-04-2008, 11:29 AM   #3
boatpuller
boatpuller's Avatar
check this picture out.the black spot's are bulb's.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 12-04-2008, 12:55 PM   #4
Red_69
Red_69's Avatar
Originally Posted by RunninLo View Post
Josh
You can buy a new "aluminum" sticker and put it on the old gauge bezel. It's abou $40 instead of close to $200 for a whole new bezel.
http://www.classicparts.com/Dash-Parts/products/349/7/0
BTW it's part#24-189A
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 12-04-2008, 01:24 PM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
There are 13 bulbs total They are as follows.....
High beam indicator = 1
Turn signal indicators = 2
Battery warning lamp = 1
Check Engine light = 1
4WD indicator light = 1
Seat belt light = 1
Brake warning lamp = 1
Gauge illumination = 5
All these bulbs on the '88-'91 model crew cabs, blazers & Suburbans are a part # PC194 which means the bulb AND socket are one unit and cannot be seperated. You can however go to your Local NAPA AUTO PARTS store and get replacement sockets. They carry them in 2 different sizes that're kinda hard to tell apart. You will need the smaller of the 2 to fit your cluster.
Just added..... Some of the bulbs may very well be a #168 These bulbs have a GREY BASE and are a part number PC168 Although the 194's can be used in place of them as well.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-05-2008, 04:29 AM   #6
RunninLo
RunninLo's Avatar
sweet I know the 168's add the 194's have LED replacements. Thanks guys.
88 4x4 crew DD
Old 12-05-2008, 04:42 AM   #7
GMC Jim
GMC Jim's Avatar
don't think you can dim the light output of the LED's.... you want to check before you go this route
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 12-05-2008, 02:23 PM   #8
rfmaster
rfmaster's Avatar
Nope, that is not true. LED can be dimmed same as old style incandescent bulbs.
http://news.thomasnet.com/fullstory/9614
http://www.ledlight.com/t10-wedge-co...led-light.aspx
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 12-06-2008, 05:35 PM   #9
RunninLo
RunninLo's Avatar
yeah I've done a few imports and cycles mostly for color change but they will dim.
Josh
88 4x4 crew DD
