Next project: 1970 K10
Anyone using a tilt column from a 73-87?
I'm kind of thinking about using a later model non-cruise tilt column so I can have all the goodies on the column.
Anyone else done this? Problems or hiccups you ran into? This one is from an 87:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Restoration Virgin!
Re: Anyone using a tilt column from a 73-87?
Hey Bob,
I took one out of my project truck (68 swb)!!!...the PO did a hack job putting it in....he had to cut the dash under the column for some reason, he also hacked up the brake/ clutch bracket to make it fit....and of course gotta convert the plug....I'm sure others will chime in, but that was my experience...You can kinda see where he hacked the dash in my build thread...page 1 post 24 last pic...
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 12-04-2008 at 01:24 PM. |
I haven't seen one up close in quite a while, but it looks like some of it's brackets are part of the column. If so, I can guess that those would need to be removed. As long as the diameter isn't much larger, I can't see that it could be too difficult.
I'm all for a little cutting a tweaking so long as it is done right! ![]()
Texas Big Wig
My dad modified one for my old truck Sinister a while back
They dont just bolt in & its quite a bit of work to modify one & in the end its not all that great of a steering column If I had it to over again, I would prolly stick with the stock non tilt or found a van tilt to put in You can PM my dad a1953mdl if you want the details on how to mod it & he may have come up with a better easier way to do it, but I know it took him a while to cut it apart & weld it back together |
Rods
![]() Join Date: Nov 2002
I have one from a 2000 i have been thinkin about
#6 | |
If I can find one cheap enough I might go ahead and pick it up and just play with it.
I put one in a 51 chevy truck im doing ,got a older model then you have . It dosent have the box at the turn signal leaver . I think they look better . The mounting bracket will come off easy and you can use Borgson u joints and shaft to the steering box . But fitting to the dash will be the most work . I have an extra one i thought about using in a 70 c/10 . But so far thing is all ive done on any of my projects lately.
Rods
If he no take then leme know
I have one on order from a guy in MI that will have the wiper switch and cruise and dimmer on it. It should be in any day now. It is rebuilt with new bearings and switchs and a 2 year warranty. the cost with a late model chevy truck wheel (88-94) was 270.00 shipped to AR. Jim
Bob, go to Anderson's, the place is full of '73 and up trucks. I think they are around $30 for a column.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Cool Chris, I guess one of these days I need to go there. It's been 15 years or more since I've been bone yard hunting.
I got your PM too, just hadn't answered yet. That would be cool, I'll probably take you guys up when the weather is nicer.
Come on, what's wrong with a test drive right now?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 12-04-2008 at 09:44 PM. |
#13 |
Keeping that couch under control is job #1 right now. I have a nice hot fire burning and am tackling that same problem!
#14 |
Restoration Virgin!
Hey Bob,
I finally found some pics of what the PO did to the brake/ clutch assembly....can you say HACK J-O-B!!!! ![]()
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#15 |
Restoring a 68 SWB
I would like some info on this too. I like the idea of having the key on the column. I hadn't thought about the wiper controls being there too, but that would be nice too.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
#16 |
I used part of one. About the bottom inch I guess, I needed the splined part to mate with the squarebody collapsible steering shaft. I must have done OK welding it, as it has held for years with no issue.:P
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
#17 |
Wow, hack job no doubt! Thanks for the pics!
#18 |
![]() Join Date: Jul 2005
I asked the same question a few days ago. Was recommended not 2 do this tilt thing . I was thinking about an 84 column. No Go, big aggravation.
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
