12-04-2008, 06:15 PM | #1 |
Eat My Rust
73-87 Disk brakes
I can't seem to find the article again (my PC refuses to use the search again today), but what all is inolved in swapping in the 73+ suspension/disk brakes? Having a hard time tracking down a frame or front end with some disks.
12-04-2008, 06:29 PM | #2 |
Re: 73-87 Disk brakes
Swap the a-arms, spindles, calipers, rotors, splash shields, flex lines, prop valve, hard-lines, tie-rods, & center/drag-link (grab the frame brake-line retaining clips while you're getting parts).
If your truck has manual steering, use the current pitman arm. If you're upgrading to pwr steering @ the same time you do the brake swap, grab the pitman arm from the donor truck (idler arms are the same). Use a 71-72 disc/drum C10 master cyl/power booster w/the 67-72 c10-specific power brake brackets.
12-12-2008, 11:39 PM | #3 | ||
Eat My Rust
Are you 100% this works? My dad is wondering about if brake line fittings will be the same, if the prop valve would work with the 71-72 MC/Booster.. And also which hardlines from the truck, just the front or front and rear? He's lookin' for a 100% "this is gonna work" from some of you guys, since theres so many articles on here with many different combination. And would the C10s or C20s have the six-lug disk brakes? When I called on junk yard, the guy got a bit uppity about me asking for a 73-87 C10 with six-lug disks, him stating only 4x4 C10s had six-lug disks. Guess I should ask for the C20s? Quote:
12-13-2008, 12:57 AM | #4 | ||
I cut the hard line to the rear long enough to allow cutting it to connect to the original 68 rear coupling/splice under the pass side of the cab. I used the calipers, master cyl, & vac booster as my core deposits for new parts. I bought rotors & calipers for a 75. I bought a master cyl for a 75 & a vac booster for a 72. I connected the m.cyl/vac booster to the hard lines & mounted the prop valve in the same place it was mounted in the 75 (front splash apron in front of the engine). I ran the front hard lines to each side of the frame just like they came off the donor truck & connected them to new rubber brakes lines (again for a 75). I installed new bushings in the a-arms & installed them in place of my originals. I installed 73 & later dropped spindles, the drag-link from the 75, & then added the new tie-rods, rotors, & calipers to the other stuff that came from the 75. The only thing that required some fabbing was the brake rod the goes from the pedal to the master cylinder. For that I used the original end that connected to my 68's pedal & 'spliced' it to the other end of the rod that came from the 75. My guess is a brake pedal rod from a 72 would be a direct swap but splicing was easier for me than searching for another (the original pedal rod wouldn't be long enough). Quote:
It would be easier to use one of the board vendors here & purchase some aftermarket 6-lug rotors that are a direct swap for 71-87 spindles.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-13-2008 at 01:09 AM. |
12-13-2008, 12:58 AM | #5 |
Happy to be here
73-87 (73-91 for Suburbans) All C-10's are 5 lug, K-10's are 6 lug, and C/K 20's are 8 lug. Also be aware that there are standard 1" and HD 1-1/4" brakes on those year models.
If you want to stick with 6 lug you need to look at the disc brake conversion that CPP offers. This is the only conversion that will allow you to go to 6 lug disc brakes on your 69.
12-13-2008, 01:46 AM | #6 | |
Eat My Rust
Who carries them? Looked through the vendors and can't find them. And about how much total did you spend? Thanks for all the info Scoti, I didn't mean to question your info, just need the details. I just have a 2000 budget to finish my truck and get it on the road, so I'm looking for the budget happiest way to get it done. Last edited by texanidiot25; 12-13-2008 at 12:32 PM. |
12-13-2008, 12:23 PM | #7 | ||
ECE p/n 03-6370-6L $89 CPP p/n CP-4R-6 $129/pair I set mine up as 5-lug & had about $500 in rebuilding the entire front end, upgrading to discs, & lowering the front of the truck.
12-13-2008, 03:08 PM | #8 |
X2 on what Scoti said. I had the entire frame cut off of a truck to ensure that I had ALL the parts I needed.
If you have your engine out, you can swap the entire cross member all at once. There are 14 bolts, 12 will line up perfectly, drill out the last two and you have it.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
12-26-2008, 02:52 PM | #9 | |
Eat My Rust
http://www.houstonpickapart.com/houston.html These yards? We had gone to Charlie's over on 2920, but he gave us another version of this swap, citing that we only needed the 73-87 spindles (but also saying a prop. valve and m/c was not needed, so rather than arguing that my dad and I just took note of this and was gonna ask else where). He was saying 35-45 perside for the spindle and brake caliper parts if I remember right. When I called CPP to order the 73-87 six lug rotors, I asked them about that, they said the 73-87 spindles will fit the 69 control arms with 73-87 ball joints and tie rod ends.. Last edited by texanidiot25; 12-26-2008 at 02:55 PM. |
12-26-2008, 07:10 PM | #10 | |
I disagree on not needing a different master cylinder & prop valve though. Disc brakes require different fluid volumes vs drums so the later disc brake master cyl is needed. Same for the prop valve.... They're proportioned according to the brake system so the drum brake prop valve will not work efficiently on the disc set-up (it would work, it just won't work @ 100% which kind of nullifies the intention of the swap in the 1st place).
12-26-2008, 11:19 PM | #11 | |
Eat My Rust
Think I'll just swap spindles at this moment. Less work and less money that can be used in the rest of the truck (Like tires for my 17 inch wheels). I'm moving from a 1990 Firebird, so just about every thing rides better than that sucker. Thanks Scoti for the info, you've been a great help. Last edited by texanidiot25; 12-26-2008 at 11:19 PM. |
01-10-2009, 10:26 PM | #12 |
Eat My Rust
Bought the spindles and calipers today, forgot the price but with a full set of seatbelts I left the yard minus $160, so not a bad steal at all.
The CPP rotors are MASSIVE! 12", 1-1/4 wide, about 15lbs each. Much beefier than some of the disk brakes on trucks today. We'll start the swap next weekend. |
10-07-2009, 01:09 PM | #13 |
Hey guys, I know this thread is old but I wanted to see if I could get some advice since I am looking at doing something very similar and going disc all the way around. I currrently have 6 lug axles drum rear (12 bolt) and disc fronts (dana 44) on a converted 71 c10 4x4. The closest kit SSBC offers for me is the 73-87 kit. Do you guys think I can do this swap without a lot of grief?
Thanks, Shawn |
10-07-2009, 02:17 PM | #14 |
Should work for you. Both are 6-lug, share common suspension parts, & would be the 1st logical choice.
02-02-2010, 04:12 PM | #15 |
Truck and auto performance nut
I'm wanting to upgrade my '68's front steering and brakes. I have the bare '68 frame (my trucks body is on a '72 chassis now) that I'm going to build up. To correct the caster issue, and get the larger 1.25" disk brakes...could I just pick up a complete '73-'76 C10 crossmember, suspension, and steering to rebuild?
I guess the question being...will a later model ('73-'76) front crossmember, etc bolt right up to the '68 p/s chassis?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
02-02-2010, 07:32 PM | #16 | |
PROJECT 7DEUCE
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 02-02-2010 at 07:33 PM. |
02-02-2010, 07:51 PM | #17 | |
02-02-2010, 11:07 PM | #18 |
original crossmember is gone...and I'm trying to get started on building up the old frame w/o having to take the truck off the road.
Oh...and thanks!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 02-02-2010 at 11:08 PM. |
02-03-2010, 03:04 AM | #19 |
Eat My Rust
I wasn't aware of any caster issues?
Noone brought it up when I had it aligned, but maybe he just ignored it since we had the control arms off, and just countered it with shims. Still (sadly) running the drum MC/prop setup, for the past year (yeh yeh, it's on the to-do list). It's very strong, only a few times have I wished for more power (highway mainly, but locking up at those speeds with even more powerful brakes woulda been worse anyways), but the setup has been solid and reliable. The cheaper $100 rotors from CPP are excellent. I do pizza delivery, so it's non-stop on those brakes for several hours sometimes. No hint of fade, warping, or heat issues, and my mom's '98 GMC Jimmy's brakes can't even take that sort of driving with out getting noisy! And even with a half ton pay load they stayed pretty cool. Last edited by texanidiot25; 02-03-2010 at 03:06 AM. |
07-02-2010, 02:01 PM | #20 | |
let me know if u or anyone else knows thanks |
07-02-2010, 03:32 PM | #21 |
They will swap. You might lose an inch or so. Maybe my '70 coils were sagging, I'm not sure, but when I put later springs in, I gained an inch or so.
08-09-2010, 12:11 AM | #22 |
SCOTI
There is nothing like experience. This information will be a great help to me on my project. Thank You |
08-09-2010, 12:19 AM | #23 |
