Old 12-04-2008, 10:23 PM   #1
61superman
61superman's Avatar
66 burb
hello all
i am sure that this question has been asked and answered but cannot find the posts so i will ask it again.
this is for all the 60-66 burban folks in the room and of course who ever else can help out
i recently bought a 1966 burb that is need of some well deserved TLC but have no idea on where to start looking.
I realize that some of the front end sheet metal will match up with the trucks but what about the rest of the body.
any information on this would be greatly appreciated.
here are a couple of pics
I NEED HELP
later
current project: 1964 chevy II Wagon
1956 3100
1972 c10 burb bagged
1962 GMC burb
1963 c10 burb
1966 c10 burb
1995 chevy lowerado 5/7 static drop daily driver
1963 c10 step side
1965 super sport impala
1967 c30
61superman is offline   Reply With Quote
Old 12-05-2008, 12:04 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: 66 burb
Yes, you are correct about the front thru the doors. Same as the pick-ups. After that you are on your own. . I have found window seals and thats about it. You may be able to use patch panels to fix your quarters, but I have seen people mention that the wheelwells are a different size on short vs long boxes....not exactly sure on that part.
I have not seen hatch supports, which I need, tailgate parts or interior stuff anywhere. I think its swap meet/classiccar salvage yard type stuff. My rear push button is messed up too. You can get taillites and fuel senders. I have also heard about people fixing the slider rails in the side windows themselves....they rot where garbage collects in the front channel.
Good luck and let me know if you find anything.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-05-2008, 10:43 AM   #3
Muleman100
Muleman100's Avatar
Re: 66 burb
I am in the finishing stages of my 66 burb. I was lucky to get a donor burb that I got the side panels from. One good supplier for a lot of burb parts is www.truckandcarshop.com I am repairing the window slide rails myself. Except for the hood and dash, I think most parts are interchangeable from the 60 thru 66 I have a source for the tailgate supports I have to look it up for you. I only like the glass work and upholstery to finish. .
Muleman100 is offline   Reply With Quote
Old 12-05-2008, 11:08 AM   #4
61superman
61superman's Avatar
Re: 66 burb
thanks you guys i appreciate the help, i like the idea that we can come here and share ideas and part info with one another because i sure feel overwhelmed with fear/anxiety. thanks again
and i will post any info that i can find on 60-60 burbs
i have another question are all bumpers for these trucks the same except the obvious fleet, stepside will any of these bumpers fit the burbs because both of mine are bent badly, or am i having these straightened. thanks
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 12-06-2008, 01:38 AM   #5
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Re: 66 burb
Yep......The front bumper is the same as the pickup trucks.....................................rear bumpers are slightly different than the front........................When it gets light out tomorrow I'll post a picture of the difference..........................I believe a front bumper will fit the rear of the 64-66 burbs.........................................Hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 12-06-2008, 10:42 PM   #6
Demmit_Hemmit's 65
Re: 66 burb
Looks like someone saved me from taking a picture.........................Look in the parts board for the sub-panel bumper for sale on e-bay...................you can see the dimples just inside the mounting holes for the bumper.............Hemmit
Old 12-07-2008, 03:03 PM   #7
61superman
61superman's Avatar
Re: 66 burb
thanks dem i appreciate the heads up
1956 3100
1962 GMC burb
1963 c10 burb
1966 c10 burb
1963 c10 step side
1967 c30
Old 12-07-2008, 03:16 PM   #8
Demmit_Hemmit's 65
Re: 66 burb
no problem........................I see by your 66 burb you have the custom mouldings on the sides............................those are pretty hard to come by........................looks like you have a pretty solid burb to start with......................good luck with your project and if i can help just hollar..............Hemmit
Old 12-07-2008, 03:42 PM   #9
Rogue
Airport Bum
Re: 66 burb
That is a spittin' image of mine.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 12-08-2008, 11:02 AM   #10
ratskin
Re: 66 burb
There is a difference in the wheel wells. The Suburban's wheel wells are shorter in length-same as the shortbed fleetside. The longbed wheel wells are about 4 inches longer.
ratskin is offline   Reply With Quote
