Old 11-30-2002, 01:42 PM   #1
72MARIO
72MARIO's Avatar
What is The Deal With Van Tilt ?
Does the coloum fit ? I have a shaft from a original auto . But do you still need to shorten the shaft ? Thanks to the person who clears this up for me!
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-30-2002, 01:56 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You will have to shorten the shaft. Most people just drill out the nylon pins so the lower piece will collapce in itself and run them that way. You should also relocate the nutral safety switch to the bottom of the column so your wires will reach it. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-02-2002, 03:28 AM   #3
the binder
i started the day attempting to install my van column and found it to be a bit of work,i drilled out the nylon bushings that leaves you with less crash cushion, the neutral switch i think can be used
in the upper position if you move the brake push rod to the other side of the foot lever, otherwise how much work is it to cut a new hole?
the binder is offline   Reply With Quote
Old 12-02-2002, 08:23 AM   #4
JimKshortstep4x4
Smile
I believe that you are better off making the hole and welding a tab onto the shift column. It is not that difficult. Moving the brake rod may cause some misalignment and binding. Also, the wiring may be a problem.
There is a magazine article on this site:
www.geocities.com/sshevnock/home.html
If you click on the link, once you get the home page, click on the magazine tech articles. Swapping out a van column is the first item.
Jim
Old 12-02-2002, 08:16 PM   #5
VDOG
Grand PooBaa Member
VDOG's Avatar
What year van column did you use? If you don't mind me asking?
I use a 76 or 77 chevy van coulmn on my truck. It installed without any trouble. I had to add a part for the netural saftey switch. But other than that, it bolted right in.
VDOG is offline   Reply With Quote
Old 12-02-2002, 08:18 PM   #6
VDOG
Grand PooBaa Member
VDOG's Avatar
Also, it does not have to be those years, 76 or 77. My father-in-law has an 83 chevy van, and his ignition is on the dash, not the column. Thats what you are looking for, dash start.
Old 12-03-2002, 03:58 AM   #7
the binder
you said you added a part is there a different netural safty switch i can use ?and i am not thrilled about taking apart my tilt mechanism,i dont know the year of the van i was to excited that i found one.
Old 12-03-2002, 01:33 PM   #8
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
That is a great link JimKshortstep4x4 !!
All kinds of cool stuff......
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 12-03-2002, 06:40 PM   #9
VDOG
Grand PooBaa Member
VDOG's Avatar
The shaft in the middle of the column is what I had to change.
Some trucks/cars have the netrual saftey switch on the transmission instead of the steering column.
So the part that looks like a half circle, that sits on the column will not work on trans netrual switchies. On the shaft, of or truck columns, there is a piece of metal that sticks up. When you put your truck in gear, this piece moves the switch and tells the truck which gear you are in. P.R.N.D.1.2.
Old 12-03-2002, 09:14 PM   #10
Southpa
Southpa's Avatar
When I installed my van tilt column I found the brake pedal arm was also hitting the neutral safety switch. I solved the problem by cutting about 1/2" off the end of the switch w/ a hacksaw. Works fine now! Sure I'm nutz...whats yer point?
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 12-03-2002, 09:39 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
SOME ERRORS
That article by Bill Turner has some errors, so don't swear by it. His articles on 67-72 GM trucks have all seemed to be a little off. There is some much better and more accurate info on this board...like on this thread.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 12-03-2002, 09:44 PM   #12
Rod
I used the van neutral safety.... just cut out a hole in same place as a truck column.... then I drilled a hole in the inner tube for the prong from the van switch to go into.... had the make an adapter for the plug as the two neutral safety switches usediffernbt plug for the nuetral safety.
If you use the trucks neutral safety then you would have to weld a tab to the tube fir the for the trucks neutral safety.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
