Old 12-05-2008, 02:24 AM   #1
liljimsrodragz
Can I use 2500lb bags?
Hey there,
Wondering if I can use the 2500's rather then the 2600 series air bags? I see that the diameters are differant though. Will that make a differance? Planning on running these in stock suspension. Should I use 2500's and 2600's? whats the best setup?
Thanks, James
liljimsrodragz is offline   Reply With Quote
Old 12-05-2008, 03:12 AM   #2
Twisted Minis
Twisted Minis's Avatar
Re: Can I use 2500lb bags?
If you already have them you can. Otherwise I would run 2600s. They will lift to the same height with less pressure, and make for a better ride.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 12-05-2008, 04:35 AM   #3
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
agreed. Also if you're thinking BBC the 2500# will have a tougher time lifting the weight.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
