Old 12-05-2008, 10:47 AM   #1
Andrew68c10
Firewall-Mounted Solenoid
I should know this by now, but can anyone tell me how to wire up a firewall mounted solenoid and which one to buy?
1968 Chevy C10 Longbed Fleetside
Andrew68c10 is offline   Reply With Quote
Old 12-05-2008, 01:07 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Firewall-Mounted Solenoid
http://www.google.com/search?q=wirin...L_enUS285US286
I Googled it for you cause it's been a while since I did mine. Definitely a worthwhile addition if you run headers.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-05-2008, 05:05 PM   #3
Gray Ghost
Gray Ghost's Avatar
I used to run on on both my other trucks, but with my Hedman Shorties I haven't had to do it on this one.
Google wiring a Ford solenoid on a Chevy.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-06-2008, 02:49 AM   #4
Andrew68c10
I have the Dynomax 3/4 length Chevelle headers still in the box. I wonder how they'll do.
Old 12-06-2008, 07:32 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
I rigged a Ford-style solenoid on my '71 Jimmy w/ Hedman headers. I mounted it on the passenger side inner fender.
Old 12-06-2008, 02:17 PM   #6
jorgensensc
jorgensensc's Avatar
Stop calling them FORD solenoids!!!!! GM used them too you know! (Only on some campers. They are all the same part number) J/K! HAHA
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-07-2008, 12:32 AM   #7
'68OrangeSunshine
Shawn
You're right. If it was a genuine F*rd soleniod, it wouldn't work. LOL
Old 12-07-2008, 09:52 AM   #8
Huck
Huck's Avatar
Actually Ford did have a better idea!!
Huck is offline   Reply With Quote
Old 12-07-2008, 02:04 PM   #9
Boog
laying low
Boog's Avatar
You know this topic comes up every now and then. I'm 54 and have heard of this "fix" from way back when but I cannot for the life of me understand how it can help a heat soak situation. You still have wires going down to the starter solenoid to activate the starter. Those wires still get hot and lose amperage same as before.
What I learned to cure the problem "way back when" was to take the starter to a local starter/alternator shop and have then beef up the starter using Delco parts, of course. A stock small block starter has 2 fields and 2 shunts adequate when new but after some time will weaken. Our starter guy put in 2 more fields doubling the starting power of the starter and solved ALL hot start problems forever. It cured the problem on every one we did. It did cost a little bit more than this ferd solenoid fix but no wiring had to be added or modified.
The only possible benefit I can see with this fender mounted solenoid is the shorter distance for the S wire to travel from a solid 12volt source so maybe less amperage drop before it gets to the starter.
Another idea is to pick up a mini starter from the salvage yard. I think they started using them somewhere in the mid 90's. I am told they are rock solid with roller bearings and planetary gear set they are stout and last forever. Anyone used these yet? It would take less amperage to turn this one over.
Boog
Old 12-07-2008, 02:54 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
I don't know why the remote solenoid works, but it does. Solved a hot start problem I was having because of my headers. I am interested in a starter upgrade at some point though.
Beat it to fit,
Old 12-07-2008, 04:02 PM   #11
Andrew68c10
I'm just getting back into this after several years off, but I remember some part that would physically sieze up when it got hot. Or maybe it was the contacts would separate when hot? I never thought amperage drop was the issue?
Old 12-07-2008, 09:30 PM   #12
Gray Ghost
Gray Ghost's Avatar
It's those damn cheapo solenoids they use now....can't take the heat. Boog's fix sounds like the bomb to me, but I have tried the F Solenoid and it does work. By using it the wire gets routed away from the headers or manifolds much better than the stock config.
I do like the idea of beefing up the starter. Yes the mini's work great...had one on the Elky and never had a problem.
Kelly
