too far north
![]() Join Date: Jan 2007
switching from 4X4 to 2wd
Ok winter is here again. I was wondering if anyone knows if it is better to switch out of 4wd once you get going and then back into 4wd when you need to take off again, or just leave in 4wd? thanks for any info, Glen
2008 Chevy Silverado 1500 ![]() 2008 Jayco Jay Feather 17c (Guest House) 2008 HHR ![]() 1974 Yamaha 500 Gas saver |
Re: switching from 4X4 to 2wd
Depends on:
1---If you are still in the mud or snow, leave it in 4x4 till you get to the road. 2---If the highway is snowpacked ( no asphalt showing ) leave it in 4x4 You definetely don't want to drive on dry asphalt for very long. Don't ever try to make a turn on the highway with it in 4x4. john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
too far north
it's mostly for city driving. I leave for work just after 5pm during "rush hour" I have 2 stop signs and a some stop lights (right turn on reds) to get to work and it seems most of the corners are slick from people spinning when they take off, so I put it in 4wd to take off, I didn't know if it hurt to put it in 4wd to take off then back to 2wd once i was moving. thanks Glen
6>8 Plugless........
![]() Join Date: Sep 2007
If you are taliking about your 08 chevy it should have an auto feature that will engage the 4wd when it senses loss of traction. If not, then I would just engage it when you think you need it at these slick intersections/corners/turns, and take it back out before you reach a highway speed. Sometimes though, these newer 4x4's won't disengage until you let out of them.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
too far north
ok thanks Dieselwrencher, I don't have the auto 4X4 (wish I did but I'm cheap) I just didn't want to tear anything up by switching it too much. thanks again for the info
