Old 12-05-2008, 06:59 PM   #1
chris91
Talking read 5-lug conversion
I have a 1964 c10. I just finished my front 5-lug disc brake conversion. I changed the ball joints and used 1984 suburban parts. Can I just swap the axles out of a 1972 c10 to get a 5- lug pattern. are the axle lengths the same from 1960 to 1972.
chris91 is offline   Reply With Quote
Old 12-05-2008, 07:02 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: read 5-lug conversion
No. The axles on the '71-up trucks are 3/4" longer. You will need a conversion axle or swap the entire housing...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-05-2008, 07:09 PM   #3
chris91
Thanks, I believe the bolt pattern would be the same 5 on 5. Is this correct.
Old 12-05-2008, 10:28 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
5x5 pattern is correct for 5-lug pickups
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
i have
