Texas Big Wig
Hey guys, here are some bags I got with a project & i wont be using them
They are un-used & in great shape (one is still in the box & on has a lil dirt on the bottom of it from some test fitting) The lil ones have 5813 cast into the rubber & the bigger ones have 5815 on them & they are single port bags Would like to get $300 plus the ride ![]() The lil plate thingies are included ![]() ![]() ![]() ![]() ![]() ![]() ![]() Measuring across the port it reads 3/4" but IDK if that means they are 3/4" or that they take a 1/2" fitting The bigger ones are 7" & the smaller ones are like 5-3/4" I assume that they are comparable to RE-7s & RE-6s They say that they have a max Psi of 180 I squished them down & they both measured about 3" compressed Give me your zip code & I can get you a shipping quote ![]() This is the info from airlift: 5813: 6" bag, 9" max. extended, needs approx. 8" circumference (so the bag won't rub), 5-7" ride height, 2275 lbs per bag load. 5815: 7" bag, 9" max. extended, needs approx. 9" circumference (so the bag won't rub), 6-8" ride height, 2740 lbs per bag load. Last edited by Spray-Bomb; 12-10-2008 at 03:03 AM. |
Re: Air Lift Bags for sale !!!
Would you consider selling just the 5815- 7 in. rear bags if so how much with shipping to 83647
#15 |
Resident of Here
Bump
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
