Old 12-06-2008, 03:59 AM   #1
DMARCUM123
rear disc
i bought the brackets from member glock to use the camaro calipers when i go to put the pads on they are too thick and the calipers are all the way in .anyone have trouble with these
DMARCUM123 is offline   Reply With Quote
Old 12-06-2008, 09:25 AM   #2
LONGHAIR
Re: rear disc
What rotors are you trying to use?
LONGHAIR is offline   Reply With Quote
Old 12-07-2008, 11:21 AM   #3
DMARCUM123
Re: rear disc
Impala
Old 12-07-2008, 11:58 AM   #4
68laydout
Junior Member
68laydout's Avatar
Re: rear disc
I had issues and had to shim the caliper to bracket mount with thick washers. I'm using 97 z28 calipers and impala rotors. Will the calipers fit over the rotor with pads on without mounting caliper to brackets. If not, you've got other issues.
68laydout is offline   Reply With Quote
Old 12-07-2008, 08:59 PM   #5
DMARCUM123
Re: rear disc
now sure 68 i will check and let you know
