wheels FOR MY 68 gmc
Hey guys would liek to know the offset for my 68 gmc thinkin of buyin some 20s for it because my old 15 rims rub the control arm would a bigger rim solve that problem ?/
Tot Roddin'
Re: wheels FOR MY 68 gmc
Probably, but you will have to make sure the back space is correct for your application. As far as the proper BS, that will also depend on your application and wheel choice.
Check out the following thread for other members specs on their wheel/tire setup. LINK One recommendation would be to take your truck to a reputable wheel shop in the area and have them help you determine the correct BS. This is something that you will want to take into your own hands as a fellow board member's specs might not work on your truck. Good luck with the decision, and after you determine what will work, post of your measurements to see what the Veteran's think. ![]() By the way... ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 12-06-2008 at 12:00 PM. |
Need more info.
Bigger rims will solve the interference problem but not the cause of the problem. If you don't have drop spindles or extreme positive offset wheels you probably have bad ball joints. Also depending on the height of tires you may run into fender interference issues. So, what suspension setup do you have and what size tire do you plan to run? |
#4 | |
