Old 12-06-2008, 12:58 PM   #1
slepysal
slepysal's Avatar
removing axle perches ?
What would be the best way to remove the axle perches on my "new" rear end? I have to weld some new ones on,but I dont have a plasma cutter or a torch. So pleaese excuse the rookie question. Any tips?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 12-06-2008, 01:11 PM   #2
Twisted Minis
Twisted Minis's Avatar
Re: removing axle perches ?
Well the best way is a plasma or a torch, or borrowing one from a friend or maybe even Home Depot (torches). It doesn't get any easier. Otherwise, cut them off carefully with a parting wheel on an angle grinder, and grind the rest down.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 12-06-2008, 04:13 PM   #3
TimE
Hey Y'all!!
TimE's Avatar
I used a 4" angle grinder with a cutoff wheel (used 2 or 3 total iirc) when I did mine. Ground off the excess with a grinder disc or you could use a flapper disc to clean it up. Just be careful because it's easy to pinch and shatter one of the cutting blades.
TimE is offline   Reply With Quote
Old 12-06-2008, 04:18 PM   #4
Thorbecke Bros.
yes, and wear a FULL face shield.
Thorbecke Bros. is offline   Reply With Quote
Old 12-06-2008, 04:19 PM   #5
TimE
Hey Y'all!!
TimE's Avatar
OOPS! Forgot to mention that. Good catch!
Old 12-06-2008, 04:23 PM   #6
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I use a cutoff wheel too. It's better than a torch or plasma if you are wanting to save them for re- use. Usually, you don't have to cut very deep... just thru the weld far enough to break them loose with a hammer & chisel.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 12-06-2008, 04:59 PM   #7
lowestsixty7
I typically will use a torch to cut off axle pads and then grind the little bit left on the axle off with a hard disc. If your good with the torch you can reuse the pads if need be.
lowestsixty7 is offline   Reply With Quote
Old 12-06-2008, 10:04 PM   #8
slepysal
slepysal's Avatar
cool thanks I have new perches ,so no need to save them. so no sawz all ?? jk
Old 12-06-2008, 10:29 PM   #9
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
PLEASE let my mistakes be a lesson to all... WEAR THE PROPPER PPE!(sorry for the graffic photos)Name:  face2.jpg
vasquezmrysvll is offline   Reply With Quote
Old 12-07-2008, 12:01 AM   #10
TimE
Hey Y'all!!
TimE's Avatar
Ouch!!!
Old 12-07-2008, 12:13 AM   #11
slepysal
slepysal's Avatar
oh man that sucks!!! hope your doing better
Old 12-07-2008, 12:23 AM   #12
joe231
joe231's Avatar
holy hell!!
when did that happen?
you bout over it?
that is one hell of a hole.
CHEVY ONLY
Old 12-07-2008, 12:46 AM   #13
vasquezmrysvll
"the other guy"
it was about 15 months ago. i broke my jaw,4 teeth, sinus canity, and cut the muscle that connects your skull and your lower jaw. physicly the only effects are limited opening of my mouth and a crazy scar. mentally it did more damage than physical. wear your safty equipment.
Old 12-07-2008, 12:52 AM   #14
joe231
joe231's Avatar
wow.....
CHEVY ONLY
Old 12-07-2008, 09:25 AM   #15
tvblazer78
Low & Fast!
tvblazer78's Avatar
Wow is right, That just made me think some..
tvblazer78 is offline   Reply With Quote
Old 12-07-2008, 01:00 PM   #16
slepysal
slepysal's Avatar
yea made me think too, like maybe to get them torched off
Old 12-07-2008, 05:45 PM   #17
noteron
noteron's Avatar
"maybe"...you saw his face...the best torch/plasma money can buy has got to be cheaper than that medical bill...
noteron is offline   Reply With Quote
Old 12-07-2008, 08:15 PM   #18
joe231
joe231's Avatar
accidents do happen, I won't hang up my grinder because someone got hurt though. how would life be if you lived by that belief? if anything, it should be an eye opener to think things through and use the proper protective equipment........
CHEVY ONLY
Old 12-07-2008, 08:33 PM   #19
nhtc33d
Do you know what caused the disc to shatter like that??
nhtc33d is offline   Reply With Quote
Old 12-07-2008, 08:39 PM   #20
joe231
joe231's Avatar
i would guess it got pinched and broke some pieces off. there are warnings about not using chipped discs, but many, including me, are guilty of still using them.
it hurts the structural integrity and they are capable of exploding with the high rpms of the grinder
CHEVY ONLY
Old 12-07-2008, 09:55 PM   #21
vasquezmrysvll
"the other guy"
i still use them myself, im only more causious now. and wear the PROPER equipment. the break was due to the wheel getting wedged/cocked, then it came apart. it hasent stoped me, i just pay more attention.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
Old 12-07-2008, 11:17 PM   #22
slepysal
slepysal's Avatar
dude you are a trooper !!! Fall of and ride again. Reminds me of when I ate it on my quad, I made sure to ride as soon as I coould, since then I dont ride as much, but I knew If i didnt ride soon after I would never ride againg. Good to hear your doing better and thanks for the advice
Old 12-07-2008, 11:19 PM   #23
TimE
Hey Y'all!!
TimE's Avatar
Agreed!! Use someone else's mistake to learn from and not follow suit. Proper PPE is always a good idea, no matter what.
Hey...wait a minute, Joe... didn't you have the entire head of your grinder break off?? (So that's why you can't hang it up. )
Old 12-07-2008, 11:32 PM   #24
joe231
joe231's Avatar
yeah I was cutting the solid steering shaft on '66, the cut-off wheel got pinched and the head of my grinder blew off...no damage to vehicle or any persons though
CHEVY ONLY
Old 12-09-2008, 11:17 AM   #25
HotRodYJ
HotRodYJ's Avatar
WOW. I always wear safety glasses ear plugs etc. Going today to get a full shield. I use tons of cutting discs and grinding discs every year. I actualkly wear out about two 4.5:" grinders each year. I did have a 1/4" thick grinding rock get into my hand once, that was bad enough. Never thought about one attaking me like that though. Hope your doing better.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
