Old 12-06-2008, 07:44 PM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Lowering Questions
I already have drop spindles, 1 in. drop springs and 4 in. drop rear springs, but I want to go lower, and don't want to keep buying springs. Can I cut a little piece of the first coil off to get the equivalent of another inch all around? I know cutting springs isn't the best but I don't have budget to buy different ones.
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-06-2008, 07:55 PM   #2
67arch
WTB:Patience and Talent
67arch's Avatar
Re: Lowering Questions
I have done it but it's easy to miscalculate. I recommend cutting less than you originally expect. It changes more than you think. I was messing around with my front springs because I am bagging anyway, I cut what I thought would be 2" drop. Ended up about 4" drop resting on bumpstops! Little at a time and you should be ok.
69 shortwide
67arch is offline   Reply With Quote
Old 12-06-2008, 08:02 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Save your money and buy the bags I was once where your at.... Now im here..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-06-2008, 08:39 PM   #4
LuckyHenriksen
Wow FRENCHBLUE that looks awesome. I don't have the coin to bag right now, but I would love to someday. I like the license plate hanging sideways.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-06-2008, 08:39 PM   #5
LuckyHenriksen
If I do cut, what do I use?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-06-2008, 08:56 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
Thanks and you can use a cut off wheel on a disk grinder just put one end of the spring in a bucket of water.
MEMBER #6377
Project "7DEUCE"
Old 12-06-2008, 09:04 PM   #7
LuckyHenriksen
Why the water?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-06-2008, 09:15 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
Keeps the spring cool.
MEMBER #6377
Project "7DEUCE"
Old 12-07-2008, 03:11 AM   #9
LuckyHenriksen
Alright makes sense. Thanks
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-07-2008, 11:19 AM   #10
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
I just did this on the front of my 71. One coil cut off will get you 2" to 2 1/2". I used a chop saw and cut right through it.
MT71c-10 is offline   Reply With Quote
Old 12-07-2008, 01:08 PM   #11
LuckyHenriksen
OK so 1/4 to 1/2 a coil should give me around 1 inch
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-07-2008, 03:06 PM   #12
SCOTI
SCOTI's Avatar
The bucket of water trick is only needed if using a torch to cut the spring. If you use a cut-off wheel, the heat is much more confined to the immediate metal & cooling-water is not req'd.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-07-2008, 03:32 PM   #13
LuckyHenriksen
Ok cool
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-07-2008, 06:12 PM   #14
MT71c-10
MT71c-10's Avatar
Hey, check my thread in the suspension forum "easy way to R&R front coil springs". There is some good info in there on cutting coils. I also have a before and after pic in there. As for how much coil to cut to get 1" of drop, I think "The Shane, the moderator" is the guy to ask. I was surprised how much 1 coil dropped the front.
Old 12-07-2008, 06:35 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
All around?
Up front,... a good rule of thumb is,... 1/2 coil = 1 inch of drop.
In the rear,... you can't cut the coils because the ends of the coils are a smaller diameter than the middle of the coil. Just add the correct size lowering block. 1", 2", etc.
Keith
Convert to disc brakes.
Old 12-07-2008, 06:41 PM   #16
LuckyHenriksen
Are lowering blocks cheaper than a new set of springs? And where do I find them
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-07-2008, 06:42 PM   #17
LuckyHenriksen
All around?
Yes I would like to drop another inch front and back, so it becomes a 4/5 drop
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-07-2008, 07:03 PM   #18
lolife99
lolife99's Avatar
You can buy them,... but look here,
http://67-72chevytrucks.com/vboard/s...d.php?t=196457
and make your own.
Longer u-bolts usually run about $25-$35. I haven't priced aftermarket blocks lately.
Also,... the FAQ section is full of good threads. http://67-72chevytrucks.com/vboard/s...d.php?t=262550
That's where I found this "lowering block thread". Save the FAQ section in your favorites,... you'll be surprised how often you look there and find answers!
Keith
Old 12-08-2008, 02:57 AM   #19
LuckyHenriksen
Looks great, is there somewhere I can buy longer U bolts? And not have them made?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-08-2008, 07:28 AM   #20
lolife99
lolife99's Avatar
Companies like CPP sells lowering blocks with longer u-bolts. Also search "u-bolts" in the suspension section. It's been talked about just recently.
Keith
