Driven a 72
Need Cheap and easy Drop. Please Help!
I was hoping some of you could give me some advice. I have just started my 72 c/10 project and while I have the bed and front all off the frame i want to drop it as much as possible without using Airbags. What are my options and can it be done with a few hundred dollars as my project is on a tight budget. Thanks in advance for any assistance.
~Grapdawg ![]() |
Texas Big Wig
Re: Need Cheap and easy Drop. Please Help!
You can get a 3/5 drop with some drop springs, adjustable panhard bar, & a bolt in notch
And if it were me I would spend a lil more money & get 2-1/2" drop spindles & drop springs in the front, instead of just springs |
Since it's a 72 & already has disc brakes, get some drop spindles & cut 1-coil off the stock springs. Cutting 1-coil is free so which helps off-set the spindles expense & won't kill the ride.
For the rear, get dropped springs & an adj. panhard bar. To keep it budget friendly, modify the stock shock brackets & build your own lowering blocks (see the lowering block info in the FAQ section).
Texas Big Wig
The only problem with running lowering blocks, is that you have to get longer U-bolts
That is all good advice. I would recommend using drop spindles up front and either buying 1" lowering springs or cutting 1 coil off. For the rear, just use drop springs. You will not need to put in a notch until you get to a 6" drop.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds |
#6 | |
The benefits of running lowering blocks is that you get drop w/o affecting the rear shock travel (the rear housing is raised while the shock mounts remain fixed) & they don't impact ride quality. Another problem w/lowering blocks is the scrub-line gets closer to the ground. 1.5" blocks is the max you should use w/15" wheels. With 2" blocks, if the tire goes flat, the lower shock mount will hit the ground. Larger diameter wheels can help here.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-07-2008 at 01:24 PM. |
Driven a 72
Thanks to all of you for the great input. Sounds like I got alittle more research to do. Sounds like there are a few ways to go about it and cant wait to learn alittle more. Thanks for the help.
~Grapdawg |
This is your 3rd major rules violation in as many days.
