Vortec in the works
Rear brake interchange
Will the backing plates and brakes swap from my 68 6 lug rear end to a 5 lug 70-72 rear end? If so what drums should I get for the 5 lug axels?
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
Re: Rear brake interchange
I do believe the backing plates are different to offset the difference in the axles lengths. I swapped aftermarket axles into my 68 housing & used 71-72 5-lug drums w/no problems.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-07-2008 at 02:46 PM. |
Vortec in the works
I guess if I bought the drums that would tell me if the backing plates work.
