12-07-2008, 10:58 AM | #1 |
Between Trucks...
3 Point Seatbelt question
Found out I'm getting 3 point seatbelts for Christmas. What size bolt should I get for the shoulder part up by the door in the corner?
Beat it to fit, Paint it to match... |
12-07-2008, 11:01 AM | #2 |
Old member
Re: 3 Point Seatbelt question
There should allready be a nut welded in place. Don't remeber the correct size, but get the right size and get the bolt in grade 8 material.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 12-07-2008 at 11:01 AM. |
12-07-2008, 11:07 AM | #3 |
The threaded weld nut in the corner is 7/16" fine thread. I used shoulder bolts for the installation so that the belt ends can swivel.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 12-07-2008 at 11:08 AM. Reason: wording |
12-07-2008, 12:12 PM | #4 |
Between Trucks...
Cool, thanks guys.
