Stray "hot" wire by the heater/AC controls
Hey folks, while trying to track down my problem with my heater and tracing the vacumn lines I pulled the ash tray and noticed this wire just sticking up in the back, not attached to anything. I pulled it out the bottom to test it and it is always hot. Does anyone know where this wire goes? Here is a picture of the wire and also the ash tray where it was found. BTW, the heater motor and AC all work.
Thanks ![]()
![]() Buford - 1971 3/4 ton, Custom Camper, 350 Th, 350 SBC. Last edited by Buford; 12-07-2008 at 05:06 PM. |
Re: Stray "hot" wire by the heater/AC controls
cig lighter
This truck never had a Cig. Lighter
![]() Buford - 1971 3/4 ton, Custom Camper, 350 Th, 350 SBC. |
![]() Join Date: Jul 2001
I agree on the cig. lighter wire. Tell tale is the "rounded" coupling in the wire end. Mounts to the round post on the back of the cig. lighter barrel. Try tracing it back to the fuse block, should be a spot on the fuse block marked "Cig Lighter" or such. Even if your Grandfather ordered it without, perhaps it slipped in as a mistake on a Monday morning or Friday afternoon build and was just "tucked" up out of the way all these years? Cig lighter wire is always hot even with ignition off if I recall.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Old member
Cig wire.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
its all about the +6 inches
if it's got any other option packages on it other than the custom camper package, then the dealer probably removed it and installed the plug in the dash to fill the hole.
