Old 12-07-2008, 11:24 PM   #1
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
suggestions for makin teh doors fit and close easier
sup i jsut got new weather stripping and put it all in but the doors are a b!tch to shut both of them, im sure somebody has had this same probelm i have tryed everything on the doors
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 12-08-2008, 12:46 AM   #2
custom63
custom63's Avatar
Re: suggestions for makin teh doors fit and close easier
Im having the same problem on my 63' and it been installed for a while now.
custom63 is offline   Reply With Quote
Old 12-08-2008, 12:53 AM   #3
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
There are alot of variables involved here. I would get inside with a dollar bill and close the door if possible with the bill between the door and the rubber. There should be a slight drag when pulled out. I would do that all the way around the door to see what areas are tight or loose. You might be able to formulate a game plan from there.
Alan's Classic is offline   Reply With Quote
Old 12-08-2008, 01:10 AM   #4
joe231
joe231's Avatar
I saw a post somewhere, they removed the latches and put a ratchet strap from door to door on the inside and left tension on the rubber for several days, believe they tightened the strap every couple days, helped to "break in" the new rubber
CHEVY ONLY
Old 12-08-2008, 01:31 AM   #5
19GMC63
19GMC63's Avatar
interesting... that's a neat idea. I've had this same problem after I did mine too. I just figured the heat of the sun in the late summer would soften them, but that never happened.
I'll have to try this.... thanks Joe!
19GMC63 is offline   Reply With Quote
Old 12-08-2008, 01:34 AM   #6
joe231
joe231's Avatar
no problem, I thought it was a great idea, so i filed it away
wish i could give credit where it is due....i just can't remember where i saw it.....
my filing system leaves something to be desired
CHEVY ONLY
Old 12-08-2008, 08:28 PM   #7
Hillbilly Deluxe 65
i think i have concluded to just bend the tabs that the weatherstripping glues to, either that or try the idea that joe231 said with a cum-a-long
1BADD65
my build thread:
