Old 12-08-2008, 12:49 AM   #1
pat123
Pat
pat123's Avatar
Best way to remove paint?
i was going to use a sand blaster but was wondering if that was the way to go or not?
Thanks Pat
pat123 is offline   Reply With Quote
Old 12-08-2008, 01:30 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Best way to remove paint?
Thanks Pat
No.... unless you are an expert. You will warp the body panels from the heat generated from the friction. (Only an experienced operator should SANDblast a body) Using soda would be good or media (shells)
If you are going to strip it yourself, I would offer the option of a good paint remover folowed by a pressure washer, (or a scraping with a credit card)
You will need to wash and neutrilize the stripper and then coat with an epoxy sealant.
Tom Vogel is offline   Reply With Quote
Old 12-08-2008, 02:16 AM   #3
cdowns
cdowns's Avatar
really depends what your taking paint off of
Old 12-08-2008, 08:35 AM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
It all depends on what you are taking paint off of. Wheels/chassis - bead blaster/wire wheel/whizzer. Body - soda blaster/whizzer/D-A sander, etc.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-08-2008, 08:37 AM   #5
mrein3
mrein3's Avatar
3M makes a product that you put in your angle grinder. I believe it is called CleanNStrip. I used it on my truck. I have found that one "pad" lasts for one body panel. One door, one side of the hood, one fender. I haven't done the box yet. The disks are about $10 each and the "adapter" they sell is around $5. No warp. Removes everything including old bondo.
I don't work for 3M but it sure is a fine product for restoring old cars.
When you get the old paint off, if there is no surface rust, immediately wipe it with laquer thinner and spray it with epoxy primer. If you had surface rust, hit that with DuPont "Kwik Prep" or similer before you epoxy.
The picture is one I lifted from 3M's website. I have found this product at Menard's and Northern Tool. I think they are a buck cheaper at Northern.
I wear a respirator when I remove all that old paint. I have no idea what is in it but I'm guessing there is some lead.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-08-2008, 09:24 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by mrein3 View Post
............When you get the old paint off, if there is no surface rust, immediately wipe it with laquer thinner and spray it with epoxy primer. If you had surface rust, hit that with DuPont "Kwik Prep" or similer before you epoxy.
Good tip... I'll be looking for them when I strip my bed. Thanx.
68gmsee is offline   Reply With Quote
Old 12-08-2008, 11:46 AM   #7
dave666693
dave666693's Avatar
They sell these at Lowe's also. Works good!
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 12-08-2008, 11:52 AM   #8
Ace in the hole
I used the norton brand equivalent called "rapid-strip". I got them at home depot and they work great.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 12-08-2008, 01:07 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Those purple things do work good, but do watch out for getting the metal too hot
I stripped an entire truck with them, but was very cautious not to get the metal hot
And definitely wear you eye protection
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-08-2008, 01:11 PM   #10
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Get what is called a tiger disk or a flapper disk, works great for taking paint out of cracks and crevises, and off of curved pannels.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-08-2008, 02:23 PM   #11
Aarons72s
I have used both a siphon sand blaster and wire wheels in a angle grinder and die grinder. The wire wheels are really quick when you use them in those tools but you will have to wear face protection with them. As both of those tools spin the wheels faster than they are supposed to go. So they really throw ther wires. I use them to the majority of the work. I use the sand blaster to get into tight spaces. Now if you have a pressurized sand blaster you have to be real careful of overheating the metal, as others above me said.
Aarons72s is offline   Reply With Quote
Old 12-08-2008, 03:41 PM   #12
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
I've used flap discs, wire wheels, stripper, sandblasting, etc. Soda blasting would most likely be the quickest and most trouble-free means of stipping the paint off of a vehicle....as long as you wash the CaCO2 residue off the bare steel with some good metal wash. But being as I am a poor white boy from the ghetto....I go to my local ACE and for 7 bucks, pick up a 20/pk of 60 grit PSA discs and get after it with my DA. Takes a little time and makes a bloody mess in the garage, but is effective and cheap for the majority of what needs stripped. For the crevices and otherwise inaccessible areas- I either use a knotted wire wheel on my grinder of do a little spot-blasting with a portable sand blast rig I have.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 12-09-2008, 08:48 AM   #13
mrein3
mrein3's Avatar
I agree a DA is a good tool to use but this poor boy can't afford the air compressor to keep up with my DA. Before I grabbed a 3M clean and strip disk I was running 5 minutes and waiting 10-15 for the air compressor to catch up. Plus the DA spits out oil and water on to the body part you are working on so you have to deal with that too.
One note on the 3M product...
One time I had two doors and a fender on the saw horses for paint stripping. I had a couple of the 3M disks and went at it. I ended up getting my grinder too hot and melting one of the 110v wires. I repaired the wire and was quickly back in business but I did take a break every once in a while after that to let the tool cool down.
Another neat thing about the 3M system, you can get flap wheels and other attachments for your grinder when you buy the $5 adapter piece. Now I keep one grinder with a cut-off wheel and the other one with the 3M adapter installed. You can get 110v grinders for $15-$20. I wear hearing protection with the cheapies but it sure is nice to have two when you have a big job to do.
'72 Malibu hard top
Center City, MN
